It is currently Fri Nov 13, 2026 2:16 am
Post Posted: Sun Jul 24, 2011 9:07 am
Hi guys,
My sierra has a problem with coolant leaking from what looks to be the pipe behind the water pump. Wondering if anyone has had a similar issue? Is this actually the pump or not? Whats the best method to fix?
Bugjuice
Post Posted: Sun Jul 24, 2011 9:23 am
O-ring that goes in the back of block were waterpump Bolts on
Get a new o-ring
Post Posted: Sun Jul 24, 2011 9:42 am
Well if it is comming out of the little hole just behind the pully, it is an indication that it needs replacing. As that is what the little hole is for. just double check it :)
Post Posted: Sun Jul 24, 2011 11:30 am
Whats the best way of getting to the o-ring? I dont think the water pump is leaking but i isnt as smooth as i would have imagined.
Post Posted: Sun Jul 24, 2011 11:38 am
Waterpumps have a bit of drag
Here from suzistore
http://www.suzistore.com.au/shopexd.asp?id=35
Post Posted: Sun Jul 24, 2011 10:39 pm
What sort of drag are we talking? It probly spins half a revolution when turned over by hand.
Post Posted: Mon Jul 25, 2011 12:04 am
My brand new waterpump that has done 0k's only does 1/4 of a turn if I try to spin it and let go.
So quite alot of drag it should have.
Users browsing this forum: No registered users and 42 guests
