It is currently Fri Nov 13, 2026 12:05 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
Post Posted: Mon Aug 01, 2011 11:45 am
usual i run my 31s on the sand the rock the mud either at 8 psi, have had them down to 3 psi for a weekend of wheeling before,
they say 10psi will hold 1 tonne of weight,
have never had a problem with the rolling off,
simexs on the other hand have a common problem with getting mud in the bead as there as a stiff side wall
The guys i wheel with either dont let them down anything below 25, on patrols, or the bead locked,
so if there just a play tire bead lock them and u wont have a problem
dodgy brothers mechanical
Post Posted: Mon Aug 01, 2011 11:50 am
Use to run my 32 inch Pedes on 5psi all day every day offroad without ever breaking a bead, did ocassionally get shit in the bead though. Have reset my bead using the small ARB compressor no problems, just stick the ratchet strap around it and pull on the outer edges of the tyre. Using the propane, accelerant method can be dangerous so I wouldnt recomend it if you dont know what you are doing.
Post Posted: Mon Aug 01, 2011 11:56 am
X2. It's been implicated in some serious injuries.
Users browsing this forum: Google [Bot] and 81 guests
