It is currently Fri Nov 13, 2026 1:06 am
Post Posted: Sat Aug 13, 2011 3:33 am
Anybody got any experience with this?
Post Posted: Sat Aug 13, 2011 3:39 am
Why would you want to make a rim narrower?
If it's a steel or 3 piece wheel it would be no different from widening.
Post Posted: Sat Aug 13, 2011 3:54 am
I have a set of 16x8's that I want to put some 7.00x16's on.
Post Posted: Sat Aug 13, 2011 4:21 am
look for wheel works/repairs in the yellow pages , they will remove the center and put a new rim on.
Post Posted: Sat Aug 13, 2011 7:04 am
for the cost of doing that you might as well buy some 16x7's ready to go... arent GV rims 16x7? or something?
edit: 16x6.5
purdy.
Post Posted: Sat Aug 13, 2011 8:28 am
I don't think you are going to be able to narrow a 16x8's that far (you'll have to take 3"out of them) because the well will be too wide.
It is hard to go past stock commercial Sierra or LJ 16x4.5" rims for 7.00's
If you want lots of offset, I've seen 16" Sierra rims re-rimmed with lada niva rims.
Steve
Post Posted: Sat Aug 13, 2011 9:06 pm
Yes, but 16"s are incredibly hard to come by in nz. What I wanted to know is how hard is it to do it and end up with the rim being square, straight and usable? :)
Post Posted: Sat Aug 13, 2011 10:36 pm
Don't try to narrow the rim by cutting a band out of it.
That is illegal because the welds will fatigue crack.
Find a 16X? rim and cut the centre out of it, fit that rim to your centre.
Lots of tractors use 16xskinny rims.
Post Posted: Sat Aug 13, 2011 10:55 pm
Why will it crack if welded correctly? The centre is welded in after all :roll:
Post Posted: Sat Aug 13, 2011 11:19 pm
the only thing to watch with agricultural rims is that SOME are missing the rolled in beadlock just inside the rim lip.
on the plus side they are generally a heavier guage steel than road going rims
but 16X 4.5, 5 and 6 " should be easy to come by
Post Posted: Sun Aug 14, 2011 1:21 am
It will crack due to the flexing of the rim.
I don't know about NZ but in Aust. rims can only (legally for road use)have a weld across them to join the band together.
No welds around the rim are allowed.
Welding the centre into the rim is allowed but only as stitches.
Laws were enacted because of the number of wheel failures after widening/narrowing.
Vehicle: LJ20 LJ50
Post Posted: Sun Aug 14, 2011 2:07 am
some of the landy rims had a deep well that would allow a 15 inch centre to be put into a 16 inch wheel.
Also try mullins or other wheel manufactureers for rim bands ( cannot for the life of me think of the correct name) as they used to sell a 16 inch wheel that would take a 15 inch centre.
Or you could just get some Suzuki wheels and bolt them straight on.
LJ had 16x4.5
1 litres had 16x5 and a some others sierras had them too. mainly utes
Camels have nice toes
I would add that it is NOT something for the home workshop amateur to try - A very specialised job indeed best left to the pro's.
Tony
Post Posted: Sun Aug 14, 2011 3:37 am
imagine your wheel breaking in half at 110km/hr... lol
Post Posted: Sun Aug 14, 2011 6:35 pm
Do they go that fast? 8O
Post Posted: Sun Aug 14, 2011 7:11 pm
As in older seriers landies or the later Disco's and Defenders? Rim width?
Vehicle: LJ20 LJ50
Post Posted: Sun Aug 14, 2011 7:19 pm
as in early land bombs series 3 etc and they are 16 x 6
You will have to measure and make sure it will fit though BEFORE you buy.
Post Posted: Sun Aug 14, 2011 10:32 pm
Will see if i can track some down and run the tape over them.
Post Posted: Sun Aug 14, 2011 10:37 pm
mine goes faster than that no worries.. lol, but 110 is the national limit...
Users browsing this forum: No registered users and 72 guests
