It is currently Mon Oct 19, 2026 4:55 pm
Post Posted: Thu Nov 20, 2008 10:59 pm
ok people if i do a 2 in the body on wt diffs could i fit 31s. With out any rubbing
Post Posted: Thu Nov 20, 2008 11:09 pm
2" body lift I'm guessing?
Yes, with a little seam bashing too
Post Posted: Thu Nov 20, 2008 11:20 pm
Wouldnt it be more sensible to do it in the toilet?? :lol:
F&R ARB air lockers, lux diffs, 4 link coil rear,
Post Posted: Thu Nov 20, 2008 11:21 pm
with standard suspension?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Thu Nov 20, 2008 11:24 pm
where it will still have standard suspension in it
hello
Post Posted: Fri Nov 21, 2008 12:09 am
if you want to shag your tyres out then go for it.
Post Posted: Fri Nov 21, 2008 1:02 am
You will need to clearance things a little but not huge amounts. Moving the front diff forward slightly helps too.
What offset rims are you going to run on it?
Post Posted: Fri Nov 21, 2008 1:25 am
i think there 1.5 inchs offset rims
hello
Post Posted: Fri Nov 21, 2008 1:41 am
probably do-able if you moved the diff forward as it would move the tyre further away from the firewall. but i'm taking a geuss that it will drive like crap offroad as slight bumps will cause the tyre to thrash the gaurds. you could always do a virtual lift and chop the guards out a bit.
79' LJ80 (sold) :(
Post Posted: Fri Nov 21, 2008 1:46 am
so wat eles would i have to do to it tomake them fit
hello
Post Posted: Fri Nov 21, 2008 1:57 am
Bump stop extensions 8)
Post Posted: Fri Nov 21, 2008 2:15 am
but another thing my 1 liter wont push 31s would it and are wt diffs a lower ratios or higher
hello
Post Posted: Fri Nov 21, 2008 2:30 am
it will turn the 31"s but any decent hill will have you burning up the clutch and going nowhere, been there done that. crawler gears are the go.
I had 31"s, 2" spring lift, no body lift, offset rims on standard 1 litre diffs and had minimal scrubbing, the only noticable place was on the springs at full lock but not enough to make it undrivable.
1 litre 4.11:1
1.3NT 3.7:1
1.3WT 3.9:1
Post Posted: Fri Nov 21, 2008 2:42 am
Got it wrong Mark
1.3WT 3.7:1
1.3NT 3.9:1
but that's OK I'll correct you
Post Posted: Fri Nov 21, 2008 3:03 am
so i got 4.11:1 diffs now im going to 3.7:1 diffs is that a higher gearing or lower and wat will it diff to the revers
hello
Post Posted: Fri Nov 21, 2008 3:44 am
dont worry greg, I knew what I meant.
noddy the simplest way to explain it is this:
4.11:1 ratio means the driveshaft rotates 4.11 times to the wheels 1 rotation.
3.7:1, same thing, driveshaft rotates 3.7 times to the wheels 1 rotation.
so the less driveshaft rotations per wheel rotation means the lower the engine revs to turn the wheels.
Vehicle: 1999 Jimny
Post Posted: Fri Nov 21, 2008 1:29 pm
umm What he said ^^^^^^^^^^^^^^^^^^^^^^^^ :lol:
best off road 4.11:1
Vehicle: MY2019 Jimny
Post Posted: Fri Nov 21, 2008 2:31 pm
It is lower - less speed, but more torque.
Post Posted: Sat Nov 22, 2008 2:18 am
i just put a body lift in so next is the wt diffs
hello
Post Posted: Sat Nov 22, 2008 3:31 am
I just had lamb korma for dinner, so next is a good sleep, then a dump.
Vehicle: 75 Cruiser
Post Posted: Sat Nov 22, 2008 3:35 am
you been hanging out on OL to much lumpy :thefinger:
Post Posted: Sat Nov 22, 2008 3:39 am
Yeah - quite possibly, every time I see a cop car, I think of RN...
Vehicle: 75 Cruiser
Post Posted: Sat Nov 22, 2008 3:49 am
see ya lost me again, RN means Registered Nurse to me :?
Post Posted: Sat Nov 22, 2008 1:39 pm
I think you mean the less driveshaft rotations per wheel rotation means the higher the gearing?
Users browsing this forum: No registered users and 288 guests
