It is currently Fri Nov 13, 2026 5:24 am
Vehicle: On the lookout
Post Posted: Tue Sep 13, 2011 4:10 am
Hi guys, I've done a search and read up on previous posts, but not quite what a definitive answer yet.
Some of you have alluded to the fact that on a jimny you disengage the hubs when in 4x4, and I THINK but I'm not sure, the front drive shaft disengages too at the transfer case?
If this is all true, then surely the front is the ideal place to put a cheap auto-locker, since it will only be in operation when you are in 4x4. Is this right? No nasty side effects at all when on-road in 2wd.
Post Posted: Tue Sep 13, 2011 4:43 am
Can't get a front auto locker for jimnys
Post Posted: Tue Sep 13, 2011 10:37 am
Replace Auto-Locker with Weldy.
A valid question. Will it still free wheel happily when not in 4HI or 4LO?
Post Posted: Tue Sep 13, 2011 10:39 am
then youll still have a problem with steep descents if in 4wd especially if its slippery
Post Posted: Tue Sep 13, 2011 10:42 am
Just get a rear auto locker or front air locker. Alot better than having a welded front.
Users browsing this forum: Google [Bot] and 74 guests
