It is currently Fri Nov 13, 2026 7:44 am
Post Posted: Fri Oct 15, 2010 5:38 am
In the process of taking out my transfer case (never done before). How do you get the small metal clamp off at the bottom of the lever? Does it split with a screwdriver?
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Fri Oct 15, 2010 5:47 am
Push down and twist.
I want my old sig back :(
Post Posted: Fri Oct 15, 2010 5:57 am
Are you talking about the hose clamp thingy that holds the rubber boot on? if so, there is a little tab folded over that holds it tight. Find the tab and open it up with a screwdriver. (It's kind of a like a compressed Z shape and unfolds)
Post Posted: Fri Oct 15, 2010 5:58 am
Ok. thanks
Post Posted: Fri Oct 15, 2010 5:59 am
See my post above.
Post Posted: Fri Oct 15, 2010 6:27 am
Ok guys, my shift lever aint moving. Boot is off and i can see the spring, everything done according to haynes manual, but the lever wont budge. i push down and turn and NOTHING. Does it need a helping hand with the hammer?
Post Posted: Fri Oct 15, 2010 6:33 am
I always left my stick on, when dropping t-case. It was easier to get at stick on the floor.
But make sure you push and twist on the bottom piece, not the stick itself
Post Posted: Fri Oct 15, 2010 6:41 am
See the bit in pic, will give you an idea how it comes out.
Same as the bit on a single stick, but didn't couldn't find a picture
Post Posted: Fri Oct 15, 2010 6:46 am
Got it. Thanks for your help.
Post Posted: Mon Sep 19, 2011 3:55 am
Hey my transfer lever is stuck in neutral. Trying to get that spring loaded thing off. I push down, turn anti clockwise. Should pop up all the way and stick should just pull out or what do I do. Been at it for last 30mins trying to twist it and get the thing off but nothing so far. Also it's really hard to twist that spring loaded thing.
Vehicle: 4wd
Post Posted: Mon Sep 19, 2011 3:57 am
Just make sure you are pushing down hard enough.
Also when taking the case out I find it easier to leave the stick in and put it into 4x4 low.
Watch out or you'll get sued.
Post Posted: Mon Sep 19, 2011 4:01 am
I'm not taking the case out. Just need the stick out. And I got it turned a bit and it still won't pop up:/
Post Posted: Mon Sep 19, 2011 4:07 am
It like got to a certain part and t won't go any further. But won't pop up either
Post Posted: Mon Sep 19, 2011 4:11 am
Got it thanks. Just the spring wasn't pushing it up it was stuck.
Vehicle: 4wd
Post Posted: Mon Sep 19, 2011 4:19 am
That was for the other guy.
Use a couple of flat head screwdrivers.
Post Posted: Mon Sep 19, 2011 5:06 am
The problem is that it's like jammed between two gears and I need to try and line up the two gaps inside the transfer case so I get get the lever in there. If you kind of get what I mean:/
Users browsing this forum: No registered users and 70 guests
