It is currently Fri Nov 13, 2026 5:57 am
Vehicle: 89 vitara
Post Posted: Mon Oct 03, 2011 6:50 am
due to bigger tires i need to lift the vitara, and cut some guards :D
im not doing a body lift, will cause to much fuss and i think they look untidy.
any way, and one have some springs laying around to measue the inside diameter so i can make some spacers? not going to pay 100 dollars for a 12 dollar peice of nylon.
cheers jordan
Post Posted: Mon Oct 03, 2011 6:55 am
I'd say a body lift is tidier and less fuss than cutting guards, but each to their own.
I reckon body work is a time consuming PITA.
Post Posted: Mon Oct 03, 2011 7:14 am
X2 on that.
either that or lift it properly... spring spacers will only limit your flex.
Stocker
Post Posted: Mon Oct 03, 2011 8:46 pm
40 mm bump stops in the rear will clear 31' on +10 rims with a little trim
Unless u go forward on the front there is heaps of fire wall loving to be done
If I was u I would go new springs
Vehicle: 1995 swb vitara
Post Posted: Mon Oct 03, 2011 9:21 pm
I have spacers fitted - 30mm
If you like I can measure them
They would be easy enough to make out of steel or alloy
But check eBay , there only like &50 or so
Personally I'd change springs and go they right way
First and flip the strut top and see how much room you have.
Vehicle: 89 vitara
Post Posted: Tue Oct 04, 2011 8:04 am
already got new springs guys ;) still rub
Users browsing this forum: No registered users and 104 guests
