It actually depends on the year - and not all G13b engines are 16v DOHC GTi engines.
I have a G13b here (which I've had from new) that is an 8V SOHC engine - with square cut timing belt, four hole bottom pulley & a multi-rib accessory belt.
I also have a G13b (that I know the history of) that is a 16v DOHC engine with round cut timing belt, five hole bottom pulley and multi-rib accessory belt.
Users browsing this forum: Google [Bot] and 66 guests
