It is currently Thu Nov 12, 2026 9:34 pm
Post Posted: Tue Oct 18, 2011 7:25 am
hi all, just got my zook back together and the only thing not working is the tacho. i'v checked all the fuses and everything i can think of but no luck. its a seirra with a g16b in it. any help or ideas would be great. thanks all
Post Posted: Tue Oct 18, 2011 7:28 am
wire is near coil, is it hooked up
Post Posted: Tue Oct 18, 2011 7:29 am
brown I think...
Post Posted: Tue Oct 18, 2011 7:30 am
steak_knife wrote:
brown I think...
Wire that is...
Post Posted: Tue Oct 18, 2011 7:58 am
year all hooked up, put a test light on all wires i could see and they seem to be geting power. i will run a few more checks around the coil tommorrow and see what happens. thanks all.
the car was in the shed for about 12 months so it may be a dodgy conection.
Post Posted: Tue Oct 18, 2011 8:09 am
mine needed a resistor/transistor/modulartronic device put between the tacho and the cable for it to get a reading... im using the g13bb computer and head, but its a similar setup isnt it?
Suzistore have since worked out how to do it also, maybe see if you can buy the little sucker off them to install?
Post Posted: Tue Oct 18, 2011 8:19 am
the wire goes to the negative side of the coil ! , and yeah its brown as stekky said , the wire that is ..
Post Posted: Tue Oct 18, 2011 7:25 pm
Do you have more info on the modulatronic device? I've got the same issue using the GTi ECU. I attach the tacho wire and the engine dies.
SS
Post Posted: Tue Oct 18, 2011 9:27 pm
no more info im afraid - a place near my house called "Applied Instruments" got mine working for $80... all i know is they pulled the cluster out and fitted a whatsydoover to convert the signal.
Suzistore then sent a few conversions there and analysed what was done so now they can do it in house themselves.
Post Posted: Wed Oct 19, 2011 10:25 pm
Sounds like I'll be giving Suzistore a call. :wink:
SS
Users browsing this forum: No registered users and 48 guests
