It is currently Fri Nov 13, 2026 12:37 am
Post Posted: Sun Oct 23, 2011 5:25 am
Hey all.
Pretty new to the forums thing so easy on me.
So i've got a nice little 92 Sierra with the G16B conversion which had already been done by a previous owner. I'm putting an adaptronic 440 ECU in the old girl but i'm looking for some help with wire identification... I've seen a few diagrams for http://www.suzukiinfo.com/ but at a glance, they don't match up to my wire colours. They must be identification for G16B's from other countries maybe. Either way, if someone out there has a list of all the ECU pins and what they do, that's probably what i need (eg. pin 4-water temp, pin 5-Throttle pos sensor etc etc)
Engine is a G16B, twin coil, waste spark, SOHC, 16V... Year model and from what vehicle is unknown. It uses a MAP sensor not a MAF sensor and no dizzy. unlike most of the diagrams i've found which tend to show a MAF sensor and even a dizzy...
Any help appreciated.
Howie.
Post Posted: Sun Oct 23, 2011 5:31 am
Where is the top water outlet? Back of head or coming out of the intake manifold?
Sounds like a later GV 2door (rareish) or Baleno motor.
Post Posted: Sun Oct 23, 2011 5:35 am
Thermostat housing is mounted on the back of the head... And yes, i was told it was a baleno motor but still not 100% sure.
Post Posted: Sun Oct 23, 2011 5:41 am
Yep. Its a 98+ Baleno motor.
Also Esteem in other markets.
Runs a crankangle sensor also.
Post Posted: Sun Oct 23, 2011 5:46 am
May be of help
http://www.ptjau.com/images/sierra/bale ... ringv1.pdf
yes that's correct. definitely has a crank angle sensor :D thanks mate. So these particular G16B's are less common than others? And idea where i can find the ECU pin identification?
Vehicle: Zookless
Post Posted: Sun Oct 23, 2011 5:48 am
Try this link.
http://www.redlinegti.com/forum/vt.19261.htm
Thanks... I'll do a cross reference some time this week to see if colours match up.
Legend.
Post Posted: Sun Oct 23, 2011 5:56 am
http://www.redlinegti.com/forum/viewtop ... 09#p358409
This may help also. Pinouts for a different model adaptronic. They have alot of baleno engine tech over there as its mainly turbo'd roadcars.
Users browsing this forum: No registered users and 60 guests
