It is currently Fri Nov 13, 2026 12:36 am
Post Posted: Thu Oct 27, 2011 12:17 am
Hey guys,
Struggling to get my head around this..
I want to put either a 1.3 or 1.6 into my maruti to replace the F10a that is currently in there with a big end issue.
Will this kit allow a 1.6 conversion to be bolt on?
http://www.lowrangeoffroad.com/index.ph ... tegory/56/
is there any non welding options for the 1.3?
Post Posted: Thu Oct 27, 2011 12:29 am
No mate. Yor engine mounts are in the wrong spot. Either you make custom mounts, or you move the mounts on the rails. :cry:
Post Posted: Thu Oct 27, 2011 12:43 am
No worries. Cheers
Post Posted: Thu Oct 27, 2011 4:01 am
to fit a 1.3 into my 1.o Sierra
I used 8 - 10 mm flat plate bolted to original chassis mounts,
with holes drilled to match 1.3 engine mounts
1.6 could work same way?
Post Posted: Thu Oct 27, 2011 4:45 am
Yes that could work, but the brackets would need to be longer still.
Post Posted: Thu Oct 27, 2011 5:03 am
I was told it be shorter, but haven't actually measured it.
But any longer than what I had, would be much too long
I think one side is in same pozzy as a 1.3?
Post Posted: Thu Oct 27, 2011 5:59 am
nice one... thanks christover..
i will give it a go :)
appreciate it.
Post Posted: Thu Oct 27, 2011 6:12 am
I think some 1.o litre marutis have similar engine and gear box mounts to a 1.3 sierra,
but only heard that, never seen one underneath
Post Posted: Thu Oct 27, 2011 6:45 am
I just cut the mounts off a 1.3 chassis and welded them into the Maruti. I fitted a Gti so that all i had to do.
Users browsing this forum: No registered users and 64 guests
