It is currently Fri Nov 13, 2026 1:02 am
Post Posted: Thu Sep 08, 2011 9:31 pm
hey does anybody know or can rebuild a stock 1.3 carbie for me im willing to pay thanks. its just that all my quotes been around 3 to 4 hundred
one day i will go fast
Post Posted: Thu Sep 08, 2011 9:46 pm
I had one rebuild by Carb Tech at Kippa Ring. I don't remember how much it cost exactly but i'm sure it was less than $300.
If I can dig up the number for them I will post it up.
edit: found it
Carb Tech
Unit 4/ 38 High St, Kippa-Ring, QLD 4021
p: (07) 32843061
Post Posted: Thu Sep 08, 2011 10:31 pm
ok thanks mate
Post Posted: Thu Sep 08, 2011 11:17 pm
They did mine about 2 years ago...still hasn't missed a beat 8)
Post Posted: Fri Oct 28, 2011 12:10 am
I am just getting mine done at carb-tech atm. it looks like is about $420 all up. That included: full acid clean, rejecting the primary and secondary, new shaft and bushes, new butterflies, new choke mechanism, new dizzy diaphragm, new idle up solenoid, removing and re-fitting to car.
Post Posted: Fri Oct 28, 2011 9:04 am
The same quotes I have got.... not cheap hey!.. and to think it's just a carby :roll:
Post Posted: Fri Oct 28, 2011 9:16 am
Was that drive in and drive out??
Post Posted: Fri Oct 28, 2011 9:31 am
I did my own carby on my old Sierra.
I bought a minor kit for $40.
Took two days on kitchen bench,
but it was never trouble again.
If you spending big money on a carby,
you really should clean fuel tank, and lines.
Fit a real good filter in stock spot,
and another after fuel pump.
New fuel pump is wise,
as the diaphragm can break off and jam up carby.
And thrown in some metho or
carby cleaner in tank once a month.
Or the shit will just stuff up ya new carb.
Post Posted: Fri Oct 28, 2011 9:28 pm
Yes....
Post Posted: Fri Oct 28, 2011 9:42 pm
That's a pretty gold deal then. It would have been tune and everything for you as well.
Post Posted: Fri Oct 28, 2011 9:45 pm
Yeah $370... which I would rather spend on gears... :wink:
Post Posted: Fri Oct 28, 2011 11:42 pm
Pointless having gears if your car doesn't go :lol:
Post Posted: Sat Oct 29, 2011 12:44 am
just got my car back. i can not believe it is the same car.... it starts and runs so well now definatley worth it in my opion. i was thinking about doing it myself but i just could not be stuffed mucking around. carb-tech did a bang up job.
they reckon most of the gunk in the fuel bowl would have been sucked in over time from the air supply. so i have order a new air cleaner seal gasket for the carbie and i will grab a new air filter. i have allready fitted a super fine fuel filtre plus a inline one after the fuel pump.
best money i have spent on car so far
Vehicle: 96 sj70+80 tintop sierra
Post Posted: Sat Oct 29, 2011 1:09 am
Just rang carb tech max will cost drive in drive ou is $450 and same day repair.
That if needs all new components
Post Posted: Sat Oct 29, 2011 3:06 am
would like to do mine aswell. does anyone know someone around the ipswich area.
Post Posted: Sat Oct 29, 2011 9:31 am
Carby is fine... just has a rather erratic idle! :wink: :roll:
Users browsing this forum: No registered users and 66 guests
