Grind as much as u can then use a cold chisel nd hit inside the crack of the sleeve. Thee sleeve should eventually crack and slide off. Bearing is a bit harder as you can't really get ion there witth a grinder.
Another hint make sure you put the backing plate on first before you press on the new bearings
Users browsing this forum: No registered users and 40 guests
