It is currently Fri Nov 13, 2026 6:49 am
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3
Post Posted: Thu Nov 10, 2011 9:25 pm
monkey wrote:
vaso wrote:
would it not be the starter motor? the battery seems to be able to handle aircon, radio and lights while running, also wouldnt it have started when i used the jumper leads to another car?
dont get me wrong, it would be great if it was just the battery....
I had a similar issue as to what your describing....replaced the battery...never been a issue sense! Can you take your battery some where to get tested?
Beat you!
That's what she said to :oops:
Post Posted: Thu Nov 10, 2011 9:29 pm
Ill get a current meter onto it within the hour, what should it be reading?
Post Posted: Thu Nov 10, 2011 9:35 pm
If it's holding charge and just been running the battery should have around 13V I think.
Post Posted: Thu Nov 10, 2011 10:03 pm
Just checked it, 12.8V just sitting there, dropped to 12.4V when i tried turning it over, is that bad? lol
Post Posted: Thu Nov 10, 2011 10:15 pm
Like I said the starter is quite heavy on power drain. I really don't know the answer though, a fair auto electrician probably won't charge you to check and diagnose. Then you know for sure what the problem is.
Post Posted: Fri Nov 11, 2011 12:52 am
Took it to an auto electrician, battery is fine, it was the starter motor, he used the "whack it while turning the key" trick and it kicked over, i didnt hit it hard enough last night :S
Post Posted: Fri Nov 11, 2011 3:10 am
Did he charge you anything?
Post Posted: Fri Nov 11, 2011 4:37 am
no he didnt charge me anything, but im sure the mechanic i took it to will :D
Post Posted: Fri Nov 11, 2011 4:41 am
at least you found out easily what the problem was.
Post Posted: Fri Nov 11, 2011 8:39 am
I agree, thanks to everyone who helped, really appreciate it
Post Posted: Fri Nov 11, 2011 8:54 am
moag stated that you can drive around with the terminal bridged , i dont recommend this . bridging those terminals is also how you check( lock) the timing , not only will it cause excessive combustion temps , it will cause the catalytic converter to melt.
Vehicle: 2001 Jimny M13A
Post Posted: Fri Nov 11, 2011 9:20 am
To read the codes you're bridging pins (terminals) B and D.
To fix the timing you're bridging pins D and E!!!
Been driving around with pins B and D bridged for a month without a problem, but will let you know if anything melts. :helloo:
Users browsing this forum: No registered users and 121 guests
