It is currently Thu Nov 12, 2026 9:18 pm
Vehicle: Sierra
Post Posted: Fri Nov 11, 2011 11:55 pm
Hi All,
I'm rebuilding my transmission today and I cant get the case apart? I have tried to use a screwdriver in the slot, however it doesn't come apart. There is loads of silicon holding it together. Any ideas? Thanks Dale
Post Posted: Fri Nov 11, 2011 11:57 pm
Screwdriver in the slot then whack with a hammer. It just needs prying apart, as long as ALL the bolts are out?
Post Posted: Sat Nov 12, 2011 12:43 am
Have you got the front cover off inside the bellhousing?
You've got a copy of the FSM and are following that right?
Vehicle: Sierra
Post Posted: Sat Nov 12, 2011 12:54 am
Yep, missed the two bolts at the top. However I have now damaged the case. Anyone have a 1.3 WT 91 transmission case? In Vic?
Thanks
Dale
Post Posted: Sat Nov 12, 2011 12:58 am
Use a rubber mellot same impact but softer on the metel
How bad? Post some pics, it might be salvageable?
Vehicle: Sierra
Post Posted: Sat Nov 12, 2011 1:35 am
A bigger hammer doesn't always pay off :(
Post Posted: Sat Nov 12, 2011 1:47 am
That's only the bellhousing, I wouldn't stress too much about it.
Post Posted: Sat Nov 12, 2011 5:37 am
Replace it if you can source one otherwise just drill a small hole at the end of the crack and call it good.
Post Posted: Sat Nov 12, 2011 7:18 am
yeah its bellhousing man, you'll be sweet, get some devcon to fix it so the crack dont spread..... best shite ever ! a guy i work with mate a keyway for his crank gear out of devcon... drives in on limiter alllll day long and no worries.
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Sat Nov 12, 2011 10:39 am
Drill a hole at the end of the crack, then weld it up? Easy done
If at first you don't succeed, get a bigger hammer
Users browsing this forum: Google [Bot] and 56 guests
