It is currently Thu Nov 12, 2026 5:26 pm
Post Posted: Mon Nov 14, 2011 1:09 am
Hi all.
Im currently converting my Sierra to a lux ifs box, (lux diffs etcetc) I am wondering what pumps everyone is using?
I think i need a Toyota pump with Multiv pulley. Is there such a thing? Will make engineering easier as then its all Toyota..
I also have a AU Falcon pump,mulitv, well known for their leaks, and are common, But will there be enough pressure for the lux box? I have seen one run with a cruiser box, but still unsure.
But what have others run?
Other info: G16b efi Suz motor, Lux diffs, 35"s. Minimal offset rims
Thanks for any help.
Post Posted: Mon Nov 14, 2011 1:13 am
lots of buggy guys up here run modded falcon pumps and seem to do ok, they are the older type with the tank built in though
Post Posted: Mon Nov 14, 2011 1:18 am
The polyvee pullied falcon pumps we've played with have been nothing but trouble - belt slippage has been the biggest issue. I think both guys that set up on them down here have gone back to vitara.
(that's with a vitara box)
Post Posted: Mon Nov 14, 2011 1:20 am
Mine has the tank built in, Tear drop shape. From memory its off an Au?
It has a 6pk pulley but will only be running a 4pk belt. A Jim ac compressor will also be on the same belt with a seperate idler/tensioner
Post Posted: Mon Nov 14, 2011 5:53 am
Falcon pump will run a lux box no problems.
Even better if you mod it for increased flow/pressure.
Post Posted: Mon Nov 14, 2011 7:17 am
Cool. I will mount it and test it then. Mod if needed later.
Thanks guys
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 74 guests
