It is currently Fri Nov 13, 2026 5:04 am
Post Posted: Fri Nov 18, 2011 7:39 pm
GV 2.4 auto. the only listing in the local shop is for repco brand oil and i dont really want to use it.
i want a good oil but will be halving the service interval and it has a 5.3 ltr sump so don't want something that is $30 a liter.
Post Posted: Fri Nov 18, 2011 7:58 pm
Have a look at the Repco stuff, some of it is made by Penrite
Post Posted: Fri Nov 18, 2011 8:02 pm
Castrol EDGE 5W-40
Vehicle: Suzuki
Post Posted: Fri Nov 18, 2011 9:18 pm
Got Penrite semi-synth in my 2.5.
Post Posted: Fri Nov 18, 2011 9:42 pm
Just because their oil is made by Penrite (the company) doesn't mean it's the same as Penrite-branded oil. They may be different formula's.
Nulon make Repco additives (oil flush etc) but I don't think they are same formulas.
2002 SWB GV
Lifted and Locked
Post Posted: Fri Nov 18, 2011 10:17 pm
think i might give this stuff a try
http://www.nulon.com.au/products/Engine ... ngine_Oil/
Post Posted: Fri Nov 18, 2011 11:19 pm
May be? Sounds like wild rumors to me
Post Posted: Sat Nov 19, 2011 12:21 am
Repco oil is SHIT!!!!!
we used to call it "water based"
Vehicle: Jeep
Post Posted: Sat Nov 19, 2011 1:23 am
I used to use Valvoline Engine Armour Semi-Synth 15W40... but after some timing chain rattle, switched to Valvoline Durablend Semi-Synth 10W40, its about $40 for 5L, and its formulated for high engine demands, like 4x4/offroad use, no more timing chain rattle... :wink: :D
Post Posted: Sat Nov 19, 2011 1:40 am
castrol
Post Posted: Sat Nov 19, 2011 2:15 am
castrol
Magnetec 10W40 for me. Can be bought for $28 for 5L when on special, which seems to be every few months.
2002 SWB GV
Lifted and Locked
Post Posted: Sat Nov 19, 2011 2:18 am
TheOtherLeft wrote:
castrol
The only stuff I use too. We use the Professional range at work
Post Posted: Sat Nov 19, 2011 2:39 am
thanks for all the suggestions however i would like to know what oil to put in a 2010 2.4 auto gv. :wink: :D ie i have no idea
what specs or grade the factory recommends, don't have a owners manual ya see. :(
Vehicle: Jeep
Post Posted: Sat Nov 19, 2011 2:53 am
Have a read here, might help...
http://www.suzuki-forums.com/2g-2006-gr ... uys-2.html
But from the quick search i did on the net, it looks like it uses 0W30 for Europe, and 5W30 or 40 Fully Synthetic for other countries...
Post Posted: Sat Nov 19, 2011 3:09 am
http://www.datateck.com.au/lube/castr_au/
5.2L
Castrol Magnatec 10W-40
CASTROL GTX MODERN ENGINE 15W-40
Post Posted: Sat Nov 19, 2011 3:23 am
5.2L
cheers big fella. big sump hay.
5.2L
pfft mini holds more
Post Posted: Sat Nov 19, 2011 3:25 am
will be about 5.5L with a filter
Post Posted: Sat Nov 19, 2011 3:29 am
5.2L
we are talking about on the inside. not what is spread all over the bottom of the car or the road or the shed floor :wink:
Post Posted: Sat Nov 19, 2011 3:33 am
5.2L
Mini doesnt leak, at all :)
Post Posted: Sat Nov 19, 2011 3:34 am
5.2L
Does it have oil in it?? 8O 8O
All pommy shit leak oil :lol:
Post Posted: Sat Nov 19, 2011 3:37 am
yep, its full :)
the reason they leak is they let mechanics that were trained on Japanese lego set cars work on them, not the craftsman automotive engineers they require
So they get put back together all slap happy with no attention paid to getting surfaces lined up, centering housing so the seal actually runs concentric around a shaft etc
some call it poor design, I like to think if it as bespoke construction :)
Post Posted: Sat Nov 19, 2011 3:59 am
You're supposed to do all that?? 8O
Post Posted: Sat Nov 19, 2011 4:26 am
I can tell you now, getting the timing cover to line up on the crank is an utter pain is the ass of a shit of a job, but the feeling you get after a long drive and you look at the top of the passenger engine mount and there is no stream of fresh oil on it makes it worth it :)
Post Posted: Sat Nov 19, 2011 4:43 am
Shit box's....... :roll:
Post Posted: Sat Nov 19, 2011 4:51 am
I think it might be why I can have a bit of a look and tickle and get a clutch to line up by eye every time :lol:
Post Posted: Sat Nov 19, 2011 5:29 am
I do to, but couldn't be bothered with any english car apart from MG's...
Users browsing this forum: Google [Bot] and 72 guests
