It is currently Sat Nov 07, 2026 8:38 pm
Post Posted: Sat Nov 19, 2011 8:41 pm
i have been trying to put my air lockers together this weekend with 4.8 diff gears from a vitara. I am having a massive amount of trouble with the diff flanges.
So far i have pulled apart 6 diffs with WT style flanges on them and only 2 of the 5 will slide onto the pinion. The others will press on and off but when you look at the wear pattern on the splines it seems they are too tall to properly fit in the flange.
Does any one know if the early WT ones were different to the coily and vitara flanges?? any one had similar issues?
Post Posted: Sat Nov 19, 2011 8:45 pm
Probably made in different village's on a Friday..
& yes I've had that trouble before, no answer for you tho... :helloo:
Post Posted: Sat Nov 19, 2011 8:48 pm
I found there were two different types of WT splines.
One had a more triangle shaped spline like the NT flanges and one had a more square shape.
http://www.auszookers.com/index.php?nam ... ion+spline
Post Posted: Sat Nov 19, 2011 9:19 pm
Can you use the Vit flange that was bolted to the pinion originally?
Post Posted: Sat Nov 19, 2011 10:02 pm
got used by the old man when he did his diffs a few months back
Post Posted: Sat Nov 19, 2011 10:54 pm
intresting i know that coiler's have a round type spline 2...
suzuki never made it simple for us
Users browsing this forum: Google [Bot] and 102 guests
