It is currently Wed Nov 11, 2026 1:18 am
Post Posted: Mon Oct 26, 2009 2:48 am
just wondering what other people have do with there sierra's when puting the gti motor in how did you fit the speed sensor I was told to use a el falcon crank sensor and make a braket up to run it of the jack shaft
what are other people using?
 Profile YIM
Post Posted: Mon Oct 26, 2009 3:31 am
the vitara VSS bolts into the sierra speedo, Fitted my NT speedo (unsure of WT dash thou).
Have to dissemble the speedo and a little wiring.
Unsure if the vitara VSS will work with the GTi ecu ? should thou it's just a pulse signal
Post Posted: Mon Oct 26, 2009 2:01 pm
That'll work, it need's a pulse sig but dosen't have to read the speed 100% true, if you can run the sig lower than the car is going the eng will go that Lil bit better.
Post Posted: Tue Nov 22, 2011 7:02 am
I found a vitara cluster a t a wrecker can somone post a pic of the vss sensor I did a search but couldnt find one just want to pull out the right bit
 Profile YIM
Vehicle: SJ51T
Post Posted: Tue Nov 22, 2011 7:46 am
I have a gti instrument cluster. Does anybody know what a gti one will look like and does it fit in the nt cluster? Also could you do it the same way jrzook did with that homemade vss?
Post Posted: Wed Nov 23, 2011 6:15 am
anyone have a pic ??
 Profile YIM
Post Posted: Wed Nov 23, 2011 6:16 am
Theres heaps of suzukis that have the VSS in them that bolts into the sierra cluster.
I pulled one from a Swift with no tach - (late 80's?) VSS must have been used to run EGR or something - pretty sure it was a carby swift.
Post Posted: Wed Nov 23, 2011 8:44 am
I have a mrk 2 in my sierra and i have no speed sensor. What is the purpose?
Post Posted: Wed Nov 23, 2011 9:07 am
It's meant to tell the comp what the car is doing and give better fuel economy
 Profile YIM
Post Posted: Wed Nov 23, 2011 9:12 am
ok fair call . mine is sweet on fuel and more than enough power. might be more so for adaptive learn. its probly something i can find out.
Post Posted: Wed Nov 23, 2011 6:14 pm
It doesn't affect normal running, its mainly for fuel cut on decelleration but is also used as one of the inputs to the IAC to simulate a 'dashpot effect' to prevent stalling when coming to a stop.
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Post Posted: Wed Nov 23, 2011 10:17 pm
I think that is only for a MK2/3 engine.....im fairly sure that MK1 engines don't have VSS
Post Posted: Thu Nov 24, 2011 6:22 am
Well my motors mk2 any one have any pics?
 Profile YIM
Vehicle: SJ51T
Post Posted: Thu Nov 24, 2011 6:57 am
ill grab my gti cluster tomorrow and try to get some pics of my vss over the weekendif you want. (if i can work out where it is in there)
Post Posted: Thu Nov 24, 2011 8:31 am
Cool thanks
 Profile YIM
Vehicle: SJ51T
Post Posted: Mon Nov 28, 2011 3:55 am
This is the best photo i could get. you cant really see anything but. The screw on the left is the VSS signal. the one on the right is the ground wire.
Looks like the write up for the home made VSS would be easier. It looks to complicated to pull the GTI speedo apart to get it out.
I think ill just use the whole GTI speedo. easier to just trim some plastic to make it fit.
Uploaded with ImageShack.us
Post Posted: Mon Nov 28, 2011 9:05 pm
thanks
 Profile YIM
Post Posted: Mon Nov 28, 2011 11:47 pm
you can build one for $5. i went to jaycar and bought a reed switch and put it in. then attached two wires (speaker) and plugged it back into my ecu...
Post Posted: Tue Nov 29, 2011 12:00 am
DIY VSS in good tech http://auszookers.com/index.php?name=Fo ... ht=diy+vss
Users browsing this forum: No registered users and 72 guests
