It is currently Mon Nov 09, 2026 10:57 am
Post Posted: Sat Dec 17, 2011 2:33 am
Hey all i have a few questions....i have searched am well ovit it! :wink:
Alright
1 does the whole diff asslembly bolt straight from a wt to a nt? as in are the spring plate doovers in the same spot?
2 the transfer case and gearbox are the same? just different length drive shafts?
3 do nt and wt springs fit in the hangers?
Thats about it i think...cheers
back in a built sierra!
Post Posted: Sat Dec 17, 2011 2:34 am
Also should of put parts will come from a wt swb to a nt lwb....cheers
Post Posted: Sat Dec 17, 2011 2:52 am
Spring perches on diffs are different.
Transfer case will be different depend on what year model Nt your talking about
Springs will fit in the hanger. Wt and Nt are the same
Post Posted: Sat Dec 17, 2011 3:35 am
1 . no , also the ratio's are different if you are only changing 1 diff...
2 . the transfer uses different flanges but are the same , you can change the flanges , or you can use the wt intermediate shaft and short slip joints off the wt for front and rear driveshafts . the gearbox is the same but may have more switches which were used for emmision control etc , dont worry about plugging them in , it will work fine
3. yes
Vehicle: nt sierra
Post Posted: Sat Dec 17, 2011 3:40 am
1. you might need longer brake lines in the front
Post Posted: Sat Dec 17, 2011 3:53 am
I've been working on this myself and have some pics that illustrate some of the differences.
I'll post something up tonight.
Post Posted: Sat Dec 17, 2011 4:12 am
You'l need to sort out a hand brake too.
NTs have them on the transfer and WTs have them on the back wheels.
Post Posted: Sat Dec 17, 2011 4:17 am
You could run no handbrake on the WT diffs and continue to use the NT trans brake.
Vehicle: Clown Car..
Post Posted: Sat Dec 17, 2011 4:34 am
keeping in mind the NT uses two lines to the rear diff, the WT uses one right!?
Post Posted: Sat Dec 17, 2011 5:41 am
Im toyin around...there is a nt long wheel base on ebay with no motor or gear box....just thinkin i could pretty much chuck everything from mine in complete diffs and all and then just get longer drive shafts.....
any way still early days!
Cheers everyone keep em comin....as for hand break.....whats that? :lol:
Post Posted: Sat Dec 17, 2011 5:43 am
i fix this by using NT master cycinder on one side and taking a little bit off the top of the WT back brake shoes. or you could just use your NT shoes, not to sure if this will work for WT rear handbrake as i used my NT T-case drum handbrake.
Post Posted: Sat Dec 17, 2011 6:11 am
Or use N/T rear backing plat's & brake's......
W/t NEED'S the H/brake to "self adjust", with out it you out of peddle all the time :helloo:
Op..... the n/t & w/t perch's are in different position's, need to be moved & the inner driver's side U bolt will need to be replaced with a longer one...
Post Posted: Sat Dec 17, 2011 6:30 am
well the missus has said im not biddin any higher then i have put in.....so i guess i will play the waiting game!
Post Posted: Sat Dec 17, 2011 6:33 am
8O
Users browsing this forum: No registered users and 32 guests
