It is currently Wed Nov 11, 2026 9:54 pm
Post Posted: Fri Dec 23, 2011 9:12 am
hey guys,
after a quick ride in gwagensteves rig it has got me thinking about line locks. i would like to fit them to my sierra however i only have drum rears and i am dubious on their capability, however i feel if i put them on the front when i am facing up hill (most likely to be using it) i will slide back as its only my upper wheels holding.
what are peoples thoughts and experiences with them?
I love lamp
Post Posted: Fri Dec 23, 2011 11:43 am
Leave it in gear..
Post Posted: Fri Dec 23, 2011 11:58 am
Yh cheers brah fanks for da top reply
I love lamp
Post Posted: Fri Dec 23, 2011 12:21 pm
You asked for peoples thoughts about the idea Bluesuzy gave you his thoughts, what was wrong with that :?
What is wrong with your hand brake ? Line locks are only as good as your brakes are, so if your brakes are stuffed fitting line locks wont improve them.
Post Posted: Fri Dec 23, 2011 12:43 pm
I was thinking more of when stopping and trying to get going on steep hills ie to give you a bit more control similar to a handbrake start but with a finger instead etc rather than replacing my handbrake with it.
My brakes arent stuffed theyre fine its more of control thing than anything
I love lamp
Post Posted: Fri Dec 23, 2011 1:20 pm
when you do a handbrake start on a hill you dont NEED to take the handbrake off... in a short uphill at low speed its often easier to just drive up with the handbrake on and take it off once you're in the clear. sure its not great for the brakes but meh, it works and saves you riding the clutch or dumping it.
Post Posted: Fri Dec 23, 2011 6:30 pm
Bluesuzy is on the money. So long as the transfer case is still in 4WD, applying the line lock to the front wheels will also lock the back because you're in 4WD the front axle can't rotate without the rear axle rotating. You might have to stand on the pedal pretty hard, but it will work.
Hop that makes sense.
Obviously, if you are on 2WD then you'll only lock the front wheels.
Mine is on the rear only because I have a rear disconnect and can use the line lock to do burns.
Post Posted: Fri Dec 23, 2011 7:53 pm
For steep hill starts in my old Sierra,
I used a hand throttle and stock hand brake.
Which was much better after a rear disc conversion.
I'm sure an idle up switch could be rigged to the carby, too.
Post Posted: Fri Dec 23, 2011 8:08 pm
If your hand brake is good enough then that's great, but they often aren't. I like the flexibility of use my line lock gives me - the fingertip control is sweet. I don't have to yank on a lever - in fact, I can even pre-engage it as they work like a one way valve - flip it on, drive up to where I wanted to be, hit the brake, and that's where it stays.
I think it's one of the those things you need to have and play with to see the full benefit of. I don't think I could be without one in a manual car now.
Post Posted: Fri Dec 23, 2011 8:26 pm
Alright thanks guys yh didnt think of it locking all 4 haha its so obvious now haha
Yh that would rape your brakes leaving the hanbrake on all the time. I guess for short stints it wouldnt be too bad
Maybe a rear disc conversion is in order.. Haha
oh so blue suzy meant with the line lock on leave it in gear to engage the whole driveline? Ok sorry mate i thought you just meant leave it in gear to hold the car and dont have line locks. Sorry the internet is so hard to judge tone, i thought you were having a dig sorry mate.
I love lamp
Post Posted: Fri Dec 23, 2011 9:17 pm
yeh no wories brah :roll:
I read it as parking onroad as you didnt specify when you wanted it on. Leaveing it in gear to stop it from rolling. I edited it last night but my laptop died while editing, so i went to sleep :lol:
I didn't have a handbrake for 3 years. You just don't need it.(except for roadworthyness)
Vehicle: 4wd
Post Posted: Fri Dec 23, 2011 9:21 pm
Good old heel to toe never fails ;)
brah
Watch out or you'll get sued.
Post Posted: Fri Dec 23, 2011 9:24 pm
brah
Does with me.
Get severe leg and feet cramps,
with doing that, and left foot braking.
Hence the hand throttle.
Got auto now, lifes much better :)
Post Posted: Fri Dec 23, 2011 9:38 pm
Haha yh but im not that coordinated haha i need some practice
I love lamp
Post Posted: Fri Dec 23, 2011 9:41 pm
You are in an ideal place to practise.
And with some hard core neighbors
Post Posted: Fri Dec 23, 2011 9:59 pm
I couldn't heel and toe fast enough to be comfortable on big sketchy climbs, and coming out of 10 years in an auto, I really wanted to regain some of the hill holding ability of an auto. Heel and toe 10 times and at least once you'll roll back. With the line lock I never roll back. Regardless of how steep the hill is.
121:1 gearing helps, but remember I have approximately zero off idle torque with the 660.
Users browsing this forum: Google [Bot] and 68 guests
