It is currently Fri Nov 13, 2026 5:12 am
Post Posted: Thu Dec 29, 2011 8:41 am
Pulling apart a G16a, putting in new front and rear crankshaft seals. Have the gearbox off, noticed that the input shaft is worn as a result of a seized bearing.
It looks like this, at the end Picture
And I'm guessing it's meant to look like this instead.
Now, I don't have the time, money or expertise to replace the shaft (I'm assuming i'd have to split the box and get in there with everytihng little and lose-able to replace it.
Is there any way to fix the shaft from it's current position? Which is poking out of the bellhousing.
I am replacing the bearing that was there, too.
Post Posted: Thu Dec 29, 2011 8:44 am
mines like that, I just stuck another spigot bearing in and didnt bother worrying about it anymore
Post Posted: Thu Dec 29, 2011 8:45 am
Don't worry about it :helloo:
Post Posted: Thu Dec 29, 2011 11:46 am
A few options I have come up with/considered:
a) Don't worry about it :D
b) get a 'wider' bearing to essentially cover the worn par by a mm either side
c) get some liquid metal/etc to pad out the worn section, then place a standard bearing over it.
A seems easiest, then B. C seems like way to much effort.
I know it will make some noise when the car is in neutral without the clutch depressed, but is there anything else to worry about?
Post Posted: Thu Dec 29, 2011 11:52 am
2 mechanic's say don't worry about it...........
Do you want a third??? :?
Post Posted: Thu Dec 29, 2011 12:09 pm
If you are really worried you can file it down so the bearing seat is uniform and then buy a slightly smaller ID spigot bearing.
Alternatively a custom sleeve is an option OR....... you could remove the shaft from the gearbox and have the spigot built up and turned back to original size.
Post Posted: Thu Dec 29, 2011 12:14 pm
There's the third.... :helloo:
4th.......... it will be fine with a new bearing... :wink:
Post Posted: Thu Dec 29, 2011 12:39 pm
Think about it - when the clutch is not depressed, the pressure plate is clamping the clutch plate to the flywheel - the crankshaft & flywheel, the entire clutch assembly, including the input shaft and the pilot shaft bearing are all rotating as a single unit - why would it make a noise?
Did you know that many late model cars don't even have a pilot shaft bearing? The input shaft is supported only inside the transmission.
I think four people have already said it will be fine with a new bearing - I'm number five.
Post Posted: Thu Dec 29, 2011 1:00 pm
Done and done. I'm not going to be 'that guy' that ignores the advice of experts.
Thanks guys, I'll update when it's all back together. :)
Post Posted: Thu Dec 29, 2011 8:01 pm
I reckon vits all do it anyway, mine was on the original clutch and the spigot bearing wasnt seized
Users browsing this forum: Google [Bot] and 80 guests
