It is currently Fri Nov 13, 2026 12:20 am
Post Posted: Fri Dec 30, 2011 8:04 am
hey guys ive downgraded to a patrol as my brother wrote of my zook recently and this thing popped up cheap as chips anyway it petrol/lpg i notoced that the flash lube hose had come of the side of carby so i reconnected it and noticed it was dripping slightly fast,
and now it is giving a constant flow of thick white smoke, is this just unburnt flash lube/valve saver escaping throught the exhaust?
tried posting this in tha nissan forumn but having trouble with account so i thought if anyone has had any experiance with lpg on shitboxes
cheers luke
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Fri Dec 30, 2011 8:18 am
it should be a very slow weap not dripping
Post Posted: Fri Dec 30, 2011 8:19 am
How much is it using? Did you put it back on where it came off? Sounds like its sucking too much out
Post Posted: Fri Dec 30, 2011 8:26 am
yeh i put it back were it came from havent run it for very long as im unsure if this will do more damage,
but yes it was a nearly constant flow so i image it is using way to much so it would burning the flash lube hence the reason he white smoke?
Post Posted: Fri Dec 30, 2011 8:29 am
I would say the smoke is just the lube burning. Does it have some kind of limiter?
Post Posted: Fri Dec 30, 2011 8:34 am
that or it's warped or cracked the head.... TB42's will do that
Post Posted: Fri Dec 30, 2011 8:47 am
yep they all do the head eventually unless u upgrade to the later model head
well so my pootrol mates reckon anyway
Vehicle: 07 vvt jimny
Post Posted: Fri Dec 30, 2011 10:49 am
he said it only started pumping out the white smoke when he reconnected the hose back up.......
mabey it has a flow regulating valve that has buggered up causing it to flow rather than drip..... check all hoses and everything on the system to make sure.
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Fri Dec 30, 2011 11:12 am
interesting.. is there anyway you can adjust the flow of the flash lube? say so it can drip and not flow?
Post Posted: Fri Dec 30, 2011 11:20 am
There should be a needle valve in the top of a small clear chamber from memory. You should adjust it so it drips I think about 5 drips a minute?
Post Posted: Fri Dec 30, 2011 9:23 pm
Get rid of it!haha i just sold mine and back into a zook.... i had tehhs ame problem with mine.....there like a screw regulater thing with a spring on it....it gos into a plastic lid thingo and the spring inside snapped or something and it was just lettin it piss threw! Thats if yours is the old style bottel one.....
back in a built sierra!
Post Posted: Fri Dec 30, 2011 9:46 pm
yeh ive been thinking on selling it since the day i got but theres ben problem after problem since and know one will buy a problem expecially if it shooting white moke out the exhaust :lol:
ye i will check that needle thing
cheers
Post Posted: Fri Dec 30, 2011 9:51 pm
I had exactly the same mate? i did mne up on 35's (Had the clearence for 37's...) did all the mods right and had problem after problem...mine was auto and there ment to bullet proof....what a croc! did 3....sold it with a blown auto in it....i had enough the missus had enough and just put it on ebay......dont miss it one bit apart from camping...
Post Posted: Fri Dec 30, 2011 9:55 pm
yeh mines on 35'' silverstones, mines a manual though, i would love to have another zook,
p.s just ran it for about 10 minutes its still blowing thick smoke as if it was on fire :roll: :roll:
Post Posted: Fri Dec 30, 2011 10:34 pm
ah shit....is the water in the radiator milky? or vise verser is the oil in the motor milky?
Post Posted: Fri Dec 30, 2011 10:42 pm
hey mate just checked all those signs and nope all is clean, im hoping its just a belly full of lube burning of as i realised it sucked 3 quatres of the bottle into the engine, :crazy:
Post Posted: Sat Dec 31, 2011 12:56 am
Disconnect the flashlube and go for a 20-30 minute drive.
This should burn out any excess oil.
Reconnect the flashlube setup and set at a drop every 5 seconds or 12 drops per minute.
Install instructions
Excess upper cylinder lube can build up in the rocker gear so I'd suggest an engine oil change as soon as you get it sorted.
Post Posted: Sat Dec 31, 2011 2:28 am
thanks jas i did just this and all sorted just have to adjust it now then reccenect it :D
thanks for help everyone
Users browsing this forum: No registered users and 41 guests
