It is currently Tue Nov 10, 2026 1:21 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2
Post Posted: Sun Jan 01, 2012 2:42 am
swifty_ano wrote:
Is anyone else noticing shit fuel economy?
no, im getting close to 390km (365km on the dash) with 31's and std gearing. :D and thats with a dented tank
Post Posted: Sun Jan 01, 2012 2:43 am
steak_knife wrote:
8O looked at your crank pulley??? 8O
seemed fine when I did the timing belt. But then again I didnt look for that problem. wasn't any movement.
How can the pulley (key way I assume cause bad fuel economy?)
I only seem to get about 250km to almost a full tank.
Post Posted: Sun Jan 01, 2012 2:54 am
Did you tighten the fruck out of the main crank bolt???
Post Posted: Sun Jan 01, 2012 2:56 am
didnt take it off because I couldn't. No oil in there so I left it.
Dodgey backyard mechanics
Vehicle: 2004 XL7 , 94 SWB Vit
Post Posted: Sun Jan 01, 2012 2:57 am
I am currently traveling 130 klm a day and consistently get over 450 KLm from a tank and 412KLm with the Air on
my vit is a 94 SWB Bog stock :P
Post Posted: Sun Jan 01, 2012 2:59 am
I remember the days of getting 350+ with the 29's and almost 500km with stocks.
Now im starting to think something is seriously wrong :(
Lately my main hang out is the fuel station.
Post Posted: Sun Jan 01, 2012 3:02 am
I do 1,000kms a week dragging a tonne of weight. I get around 500klms per tank :helloo:
Oh wait........
Post Posted: Sun Jan 01, 2012 3:03 am
Oh wait........
different vehicle? :lol:
Post Posted: Sun Jan 01, 2012 3:04 am
Maybe......
Post Posted: Sun Jan 01, 2012 3:33 am
Do I have to take the belt off to check the Pulley for play?
Post Posted: Sun Jan 01, 2012 3:38 am
you could use a timing light & watch for variant's at idle...
Post Posted: Sun Jan 01, 2012 4:13 am
The bottom pulley seems to move a bit at idle.
when revs are applied seems to run true.
Its not just not an illusion the pulley moves side to side.
Post Posted: Sun Jan 01, 2012 4:14 am
Also tried to use the timing light but its broked :(
Post Posted: Sun Jan 01, 2012 4:18 am
How I told with mine is by pulling number 1 plug out, turning it over to jsut before tdc on the timing mark and sitting a piece of stiff wire on the piston and turning it over by hand and watching
if the wire starts to drop before the timing marks line up on tdc you have dramas
Post Posted: Sun Jan 01, 2012 4:26 am
could the flogged keyway have anything to do with the irregular idle?
Post Posted: Sun Jan 01, 2012 4:28 am
Fuck Yeah!!!! :helloo:
Post Posted: Sun Jan 01, 2012 4:30 am
didnt with mine but my idle control worked
unplug the idle control solenoid thingy, then there is a black rubber bung on the throttle body with the base idle speed screw under it, set your idle to 1000rpm and see how it goes for a while, if it still gets the funny I reckon its a leak (your hoses are all terrible you can tell just from those pics)
even go and replace all those spring clamps with proper screw ones and put zipties on all the little vacuum hoses
Post Posted: Sun Jan 01, 2012 4:32 am
Guess i'll go in for a closer inspection.
Could anyone with a bit of time explain what the key does (i assume takes the pressure off the bolts) and how a flogged keyway can affect so much?
Post Posted: Sun Jan 01, 2012 6:22 am
Ok it is official.. my cat converter has collapsed as it was rattling like crazy. Could this be causing it. Maybe the insides are loose and when i hit a bump or something they jump up and block it again?
Post Posted: Sun Jan 01, 2012 6:29 am
Pull it out, gut it then put it back in and try it.
Post Posted: Sun Jan 01, 2012 11:48 am
Then replace it so the squid stand a chance.... :helloo:
Post Posted: Sun Jan 01, 2012 7:23 pm
Who cares about the squid :crazy:
It's the penguins I like :D
Post Posted: Sun Jan 01, 2012 7:51 pm
Cheers guys. The whole exhaust Is shagged. Muffler is dinted like no tomorrow and all the mounts are broken. I am planning on getting a new one when I have the time.
I shall gut it today :)
Post Posted: Sun Jan 01, 2012 8:21 pm
So the exhaust bolts are not coming off without persuasion. The sockets/spanners just slip on the nuts. They don't seem to be metric or imperial atm. They must be frucked.
Post Posted: Sun Jan 01, 2012 8:25 pm
Grab ya can of wd-40 and dose all the nuts in it then leave it for a bit
Post Posted: Sun Jan 01, 2012 8:38 pm
they are metric...
Rost Off Ice FTW... and Non-Multi Hex Sockets :)...
...or if all else fails!
...a slightly larger hammer
Stocker
Post Posted: Sat Jan 14, 2012 5:02 am
So it seems I am definately not alone with idle issues. So I hope my experience may be of some help.
So I have tried numerous things to try and DIY fix my idle problem. Now one of the other things I have tried and others have suggested may be causing your problem.
My problem was a carboned up throttle body. Now this is very simple thing to clean. Unfortunately I didn't take photos to write up a how to.
In summary (you may have to remove the obvious bolts ):
Remove airbox lid
Remove intake pipe
Remove hoses from intake pipe(remember where hose came from!!)
Remove coolant lines from bottom of throttle body (you may lose a tad bit of coolant, so remember to top it up after)
Now remove the 4 fasteners on the throttle body (top two are nuts and bottom two are bolts. )
Remove tps wire clip (important!!! Do not adjust or move the tps in any way)
Now the throttle body should slide off.
The inside of it should be all carboned up. There is a little screw on the top (outside) of the TB. Unscrew that all the way. This is your idle control screw. This was the culprit on my car. This was full of carbon and affecting the airflow. (My guess. I'm no mechanic)
Now no soak everything you can with Carby cleaner/throttle body cleaner and clean with a tooth brush. Now obviously, don't wash with water or clean the coolant jacket thingo (on the bottom) with carby cleaner.
Make extra care to clean the little screw hole as good as you can.
Now once clean. Screw that screw all the way in. Now 1 1/2 turns outwards should get you close.
Reassemble by doing the steps in reverse.
Start and test it. I'm pretty sure you can't adjust the idle until car is at operating temperature.
Once warm. Adjust the idle screw to recommendation in manual. My 1996 g16b is 800rpm.
Screw the screw in for lower rpm and out for higher.
Now I'm no mechanic and don't claim to be. Just hoping I May be able to help someone.
(Will proof read once on my laptop)
Users browsing this forum: No registered users and 106 guests
