It is currently Mon Nov 09, 2026 8:32 am
Post Posted: Wed Jan 18, 2012 6:06 am
Went to put my locker in my Jimny and I have discovered a problem
I can't seem get the diff center in because the copper tube is in the way.
The Jimny front diff housing is a stupid design.
They give you no clearance at all, I have 1mm of clearance right around the center to play with. There are slots in the bolting ring that alouds the crown wheel to go through. So only one way it will go it.
Here is a pic, sorry it's bad qaulity not much light.
Tube in the way
Slot in bolting ring
Post Posted: Wed Jan 18, 2012 8:06 am
Can you push the brass tube more towards the front? So it kinda goes infirst?
And how much was your locker?
Post Posted: Wed Jan 18, 2012 8:23 am
That's what I did but it's awfully close to the crown wheel now. Hope it doesn't come in contact with the crown wheel, that would be bad
$1126 :( rear one was cheaper
Post Posted: Wed Jan 18, 2012 8:37 am
bugger, i have no idea......
if i was very very shep, i would grind the tiniest bit out of the housing to slide the tube through....
Post Posted: Wed Jan 18, 2012 8:42 am
when we did ours it didn go over the crown wheel but it hit on the housing at the front
which peirced the copper had to ground the housing center out enough to let the copper fit with enough movement
works a treat now
dodgy brothers mechanical
Post Posted: Wed Jan 18, 2012 8:50 am
It's all bolted in now I just reshaped it around the front of the crown wheel and it went straight in.
Post Posted: Wed Jan 18, 2012 8:51 am
does it work proper
Post Posted: Wed Jan 18, 2012 9:05 am
You mean does the locker work not sure everything isn't back together yet
Users browsing this forum: Google [Bot] and 44 guests
