It is currently Tue Oct 20, 2026 5:15 am
Post Posted: Sat Feb 07, 2009 6:10 pm
i have 2 arb bars one fits well but is a bit bent and the other one is
a winch bar with the mounts hacked off and some damage to one off
the side bits.
problem is i have a winch that i wont to fit and the bar on my car
will be a bit hard to put a winch in as it is a bit not square. and it
would take a fair bit of work to fit my winch bar.
so what i was thinking off doing was to cut the winch bit out of the
winch bar and then glue it in my non winch bar. is that problem solved?
Post Posted: Sat Feb 07, 2009 6:38 pm
just make sure you use metal glue :?
or you could just get tails83 to make you one?
http://www.auszookers.com/index.php?nam ... pic&t=3790
Post Posted: Sat Feb 07, 2009 6:52 pm
yep dodgy
do it my way, then it won't break :wink:
Post Posted: Sat Feb 07, 2009 7:07 pm
whats your way ball?
Post Posted: Sat Feb 07, 2009 7:32 pm
so you want to take the midel section out and weld it into the other bar so you can use a winch?
if it is how good can you weld? personaly if you dont weld for a living then i would uses any parts you welded for recovery. my winch bar is 100% bolt on
navara on 33s. hopfully rear air locker soon
Post Posted: Sat Feb 07, 2009 8:06 pm
can't tell you
secret fitter trick :lol:
Post Posted: Sat Feb 07, 2009 8:09 pm
as long as the main cradle part is the piece that bolt's to your chassis shouldnt be a problem. Then just weld the outer sections to your new center
Post Posted: Sat Feb 07, 2009 8:16 pm
ball owns a fabrication/machine shop he does the important stuff for me.
by the way ball what does a $250k cnc lathe smell like when it is on fire. :lol:
Post Posted: Sat Feb 07, 2009 8:38 pm
it smells like a $250 cnc lathe on fire :D
Post Posted: Sat Feb 07, 2009 8:59 pm
Like very very burnt toast :cry:
Post Posted: Sat Feb 07, 2009 9:09 pm
Post Posted: Sat Feb 07, 2009 9:10 pm
Post Posted: Sat Feb 07, 2009 9:25 pm
it is a $250000 lathe. oops sorry was. :lol:
Post Posted: Sat Feb 07, 2009 9:58 pm
$2.50 now
Users browsing this forum: Google [Bot] and 287 guests
