It is currently Fri Nov 13, 2026 5:16 am
Post Posted: Wed Jan 18, 2012 10:38 am
Apart from the spring rates and load rating what are the phisical differences between the GV and XL7 rear springs?
Vehicle: Jeep
Post Posted: Wed Jan 18, 2012 1:47 pm
The only thing i have discovered so far, is that the XL7 are slightly longer and give a bigger lift if put in a GV... someone here said the XL7 rear springs fit loosely if fitted to a GV, but i asked the mechanic at Suzistore about XL7 springs going into a GV, and he said it was no problem...
Post Posted: Wed Jan 18, 2012 8:22 pm
hmmm. Im tepted to fit some to the back of my GV as it needs a little more height at the back......might have to do some more digging.
If they sit loose then you can slide gargen hose over the lower coils
Vehicle: Jeep
Post Posted: Thu Jan 19, 2012 6:58 am
If you do fit them, i would be interested to know how they go... :D
Post Posted: Thu Jan 19, 2012 9:40 am
Same here.
From what i can put together the spring seat on the XL7 diff is a little different to the GV (the whole XL7 diff is different to the GV), but the top mount pretty sure is the same. I'm not 100% sure of this though, can't find a decent pic of an XL7 diff to compare.
What have you got in the rear at the moment?
My Grand Vitara
Vehicle: 2002 GV V6 and self shifter
Post Posted: Thu Jan 19, 2012 1:08 pm
Not sure how much help this will be as I have not seen rear springs for either with my own eyes - yet, but the ironman catalogue has specs for it's springs
GV
end ID's = 62/80 (mm)
wire diameter = 12.5mm
XL-7
end ID's = 63/96 (mm)
wire diameter = 14mm
Those specs indicate that the XL-7 spring might be a fairly good fit at one end but a bit loose at the other (not sure which end is which)
Without spying it, I'd be a little concerned with the lager end not sitting on the perch properly and maybe hanging over the sides. That'll depend on the OD of the perch tho.
Post Posted: Thu Jan 19, 2012 9:04 pm
hmmm thats some usefull info right there.
Might have to see if i can borrow some to do a test fit on the spare rear housing i have here.
Vehicle: Jeep
Post Posted: Thu Jan 19, 2012 9:57 pm
I contacted the mechanic at Suzistore, he is gonna measure up the stock XL7 and GV springs, and the rear spring mounts at work today, and will get back to me this arvo, as he has access to all of it... :D
Edit: Unfortuantely, the XL7 springs and mounts he thought were there, had been sold... so no measurements...
Users browsing this forum: No registered users and 84 guests
