It is currently Fri Nov 13, 2026 4:45 am
Post Posted: Sun Jan 22, 2012 9:42 am
Hi,
I have a 88.5 sierra with a G13A motor. I thought the battery was dead so replaced it. Turns out i have a bigger issue. Dash lights and stereo works, hit the ignition and it just clicks. You can push start it and it starts and runs, you turn it off and it will start again no worries. Even take it for a run and it will start a couple hours later with no issues. But over night and its dead again, not the battery its holding charge, voltage is still 12.65.
Can anyone offer and advice? I did think maybe starter solenoid, i dont really know much about solenoids so am happy for someone to enlighten me.
Bugjuice
Vehicle: Sierra SJ70
Post Posted: Sun Jan 22, 2012 9:46 am
yeah im having a problem starting my sierra now...doesnt start straight away but eventually it does...
my voltage was fine - 12.7 i think it was. then with car turned on it was over 14 volts so i know alternator is fine...did u test your voltage with motor on?
think my starter motor might be dodgy...or might be the cables...they look pretty shitty atm.
Post Posted: Sun Jan 22, 2012 9:51 am
Its known as the dreaded clicky start and is very common on sierras a few of the other boys might chime in soon but do a search on clicky starter and ull find u can buy an upgraded wiring package. It has to do with the starter motor not getting enough power from the stock wiring
I love lamp
Vehicle: 89 SWB Sierra (soft top)
Post Posted: Sun Jan 22, 2012 10:10 am
or your battery nutruel isnt connected, try that.
Vehicle: 1985 Holden Drover
Post Posted: Sun Jan 22, 2012 10:13 am
Sounds like a similar problem mine had. You can keep trying and trying and it eventually gets it?
I got one of Royces starter looms and havnt had a drama since!
1989 WT Sierra.
Post Posted: Sun Jan 22, 2012 10:15 am
http://auszookers.com/index.php?name=Ne ... cle&sid=40
I love lamp
Post Posted: Sun Jan 22, 2012 10:36 am
Could ve your solenoid on you starter or your actual starter it might fix it try start it when it clicks give the stater a few taps with a hammer and try again if it starts it's stater
Post Posted: Sun Jan 22, 2012 8:10 pm
Joshyboy26 wrote:
http://auszookers.com/index.php?name=News&file=article&sid=40
I'd go with that, and hey it's only $30 so it's worth a shot right?
1989 WT Sierra.
Post Posted: Sun Jan 22, 2012 11:59 pm
mine does this, give the starter solinoid a tap with a hammer, if it starts then i would say your up for a new solenoid.
oil lights are like oven alarms, let u know its co
Post Posted: Mon Jan 23, 2012 3:20 am
Cheers guys,
Ill give it a whirl when i get home tonight.
Yeah its 13.5 volts when charging!
Interesting clicky starter ill see how it goes.
Bugjuice
Post Posted: Mon Jan 23, 2012 5:26 am
this is the 1 I got,....
http://www.lowrangeoffroad.com/clicky-starter-kit.html
mine completely gave in about 2 years ago..never had a problem since, actually forgot I even fitted it.
Post Posted: Mon Jan 23, 2012 6:08 am
cheers for the help fellas :D
Post Posted: Mon Jan 23, 2012 9:15 pm
Well i figured out that its the solenoid. Tap with a hammer and away we go. That will give me something to do over the long weekend.
Thanks for the help!
Vehicle: '92 Sierra
Post Posted: Mon Jan 23, 2012 9:35 pm
Regardless I'd still be upgrading the loom. The voltage drop on the stock one is too high. They start like a different car after doing it.
Users browsing this forum: No registered users and 73 guests
