| Author |
Message |
Che
Joined: Thu Mar 11, 2010 10:30 pm Posts: 2401 Location: Perth
Vehicle: LPG 1.6 Sierra
 Posted: Sat Jan 07, 2012 8:36 am |
Hi guys. What's the best way to get silicon off? A previous owner has gone a bit crazy with the stuff along a couple of seams, but want to get it all off so I can lay a bit of paint down
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sat Jan 07, 2012 8:50 am |
use hammertone paint.
problem solved
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Sat Jan 07, 2012 8:52 am |
atari4x4
 Posted: Sat Jan 07, 2012 9:07 am |
shep wrote: use hammertone paint.
problem solved
fish eyes in a can, spray painters worst nightmare
i'm no painter but, i'd clean it up as much as possible, prep the area, wash it with prepsol/wax n grease remover & hope for the best or go back to bare metal. pretty sure there is a silicone type additive that you can get for contaminated cars that you mix with the paint to stop the paint reacting with the silicone when spraying with a gun/compressor.
paging ajsr...
TheOtherLeft
Joined: Sun Aug 27, 2006 11:30 pm Posts: 818 Location: Sydney
 Posted: Sat Jan 07, 2012 9:27 am |
Not sure about Silicon, but I use Eucalyptus oil cleaning up Sikaflex. Works brilliantly.
_________________ 2002 SWB GV
Lifted and Locked
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Sat Jan 07, 2012 10:03 am |
atari4x4 wrote: shep wrote: use hammertone paint.
problem solved fish eyes in a can, spray painters worst nightmare  i'm no painter but, i'd clean it up as much as possible, prep the area, wash it with prepsol/wax n grease remover & hope for the best or go back to bare metal. pretty sure there is a silicone type additive that you can get for contaminated cars that you mix with the paint to stop the paint reacting with the silicone when spraying with a gun/compressor. paging ajsr...
plastic scraper (if you dont want to scratch shit) other wise steel is better
and then prepsol and your fingernail.
sometimes those pinstripe removal wheels work well to
silicone sucks balls and is for lazy fuckers
oh and for painting silicone drops stops fish eyes.
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Sat Jan 07, 2012 10:07 am |
high powered gerni
sand blaster
soda blaster
Petrol
Acid
That selleys stuff is basically petrol/acid mix in a gel
I am a tight arse so I would use my fingers as much as I can then rub with petrol, getting a terrible headache, then finish with acetone for the remants.
If you have a air compressor then you could soda blast it.
_________________ Camels have nice toes
zook_ute
Joined: Sat Nov 14, 2009 10:30 pm Posts: 246 Location: glasshouse mtns
Vehicle: 1995 soft top vitara
 Posted: Sat Jan 07, 2012 10:56 am |
give some carby cleaner a go, that stuff is good for everything
_________________ turbo vitara, fark yeah.
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Sat Jan 07, 2012 11:34 am |
TZAR wrote: If you have a air compressor then you could soda blast it.
i imagined 50% caustic soda in a paint sprayer... that would strip anything, including all the aluminium within 500m. glad to see its only baking soda!
rabrarley
Joined: Thu Mar 24, 2011 8:43 am Posts: 24 Location: adelaide
 Posted: Sat Jan 07, 2012 12:12 pm |
you can buy a rubber wheel that fits in your cordless drill, doest effect paint at all, i used it to take of glus from a jet ski matt, couldnt believe how easy it was, depending on how much ther is i would try an eraser just to see how it goes
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Sat Jan 07, 2012 1:42 pm |
I use a wire wheel mounted in the drill or the sand blaster ($30 from Supercheap, you'l need a good air compressor though!).
wolf_rt
Joined: Mon Jan 23, 2012 7:56 am Posts: 235 Location: Toowoomba, QLD
 Posted: Tue Jan 24, 2012 1:38 pm |
dusting the silicone affected area with plaster dust will allow you to paint over it without fish eyes... doesnt do much for the gloss level though.
gregdixon
Joined: Sun Dec 28, 2008 10:30 pm Posts: 1017 Location: Perth
Vehicle: 2004 SQ625 GV
 Posted: Tue Jan 24, 2012 10:22 pm |
Hybrid
Joined: Mon Apr 21, 2008 11:30 pm Posts: 1095 Location: Bulimba, Brisbane
Vehicle: '92 Sierra
 Posted: Tue Jan 24, 2012 11:19 pm |
sideways wrote: I use a wire wheel mounted in the drill or the sand blaster ($30 from Supercheap, you'l need a good air compressor though!).
Sand blasted a swingarm with a sticker on it back when I wasn't so sharp (16) and I had a permanent embossed sticker outline as it chewed the metal around it but did not a lot to the sticker. Does this not happen with the silicon?
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Wed Jan 25, 2012 2:01 am |
Hybrid wrote: sideways wrote: I use a wire wheel mounted in the drill or the sand blaster ($30 from Supercheap, you'l need a good air compressor though!). Sand blasted a swingarm with a sticker on it back when I wasn't so sharp (16) and I had a permanent embossed sticker outline as it chewed the metal around it but did not a lot to the sticker. Does this not happen with the silicon?
YEP. You cannot blast silicone off metal with sand or soda.
