It is currently Thu Nov 12, 2026 9:59 pm
Post Posted: Fri Feb 03, 2012 9:28 am
Ok, So I am lazy and don't want to climb under the car right now...
Is the front prop Shaft longer or shorter than the back, and what would be required to convert one to a rear?
The diff ends would be the same, but the T-case end not.
Option 1. I have been told that the T-case output plates may be interchangeable so that would mean a front plate could then just be swapped in.
Option 2. Make an adapter plate
Option 3. Redrill the holes in the rear output plate. Would the prop end surface mate ok?
Personally, I like #1 if its possible. :|
Users browsing this forum: No registered users and 64 guests
