It is currently Thu Nov 12, 2026 6:59 pm
Vehicle: Sold zuk got a Bt50
Post Posted: Tue Feb 14, 2012 9:45 am
Ok as some of you might know Im having a little bit of a problem with my engine wiring.
When I got the car the engine bay wiring was all cut up and with really no headlight, blinker horn plugs attached to it plus a heap of other random cables that have been cut. So I decided to ditch it and get a new (used non cut) WT sierra engine bay loom.
I got the WT one because I have a WT dash (was already installed) the dash had an AC button on it, but not really ready to install AC at the moment. So just got a standard WT loom. But my problem is that the plugs coming from the cab don't match the engine bay loom plugs not even the same colors.
My question is, Is the AC and non AC wiring different and is NT and WT engine loom different.
Or how hard is it to change the dash wiring? Still need to find out if I can plug the new lot into my sierra ECU
I cant seem to find a wiring diagram with a AC on it to try and compare the two.
bt50 now but still love the zooks
Post Posted: Tue Feb 14, 2012 10:21 am
The engine bay loom is pretty basic on a sierra... If your looms don't connect (it sounds like your WT dash still has the NT loom?) I would be inclined to just connect the plugs from your new loom to the cut wires on your old loom... that's going to be a lot easier than replacing the dash loom.
Is the 'cuts' on the old loom near the plug ends? (ie. headlights)
if so it should be pretty basic to lay the loom in the car and see where each wire goes from its position.
Do you know if the dash loom is working properly?
What is this 'Sierra ECU'??? I thought all Aussie Sierras were carb?
Post Posted: Tue Feb 14, 2012 1:51 pm
Little problem with the loom I left it at stekies house but when he moved he must have thrown it out I thought it was going to be an easy plug n play. its not an ecu as such just a little metal box that my interior loom is plugged into. So look like a whole dash rewire as well
Post Posted: Tue Feb 14, 2012 2:29 pm
stuff that, just get a loom that fits your dash plugs.....
Post Posted: Tue Feb 14, 2012 2:38 pm
The little metal box could be the a/c controller thingy that goes under the passenger footwell shelf....
 Profile WWW ICQ YIM
Post Posted: Tue Feb 14, 2012 4:18 pm
Yep that's the one
Vehicle: 2018 DMAX
Post Posted: Tue Feb 14, 2012 6:51 pm
Can you post a picture of the looms and plugs?
Im just wondering if something funny was done when the EFI was fitted..
Post Posted: Tue Feb 14, 2012 8:04 pm
Yeah ill post a picture tomorrow when its light
Post Posted: Wed Feb 15, 2012 4:07 pm
These 3 are the engine loom
And these 4 are the one out of the cab/dash im guessing 1 of them is the AC
Vehicle: 2018 DMAX
Post Posted: Wed Feb 15, 2012 7:33 pm
Single pin white/yellow comes from alt and should connect into interior loom w/y.
Blue plug should have a partner same colour inside.
White plug should have a white plug in the cab.
These three should have there matching plugs top left behind dash....
4 Pin 18mm wide, should be female? blue/yellow, blue/red, blue/white and blue. Is window wiper.
6 pin thats now 5 pins, almost looks like the plug up behind the cluster... but its on the wrong side?
NFI on the others though :? Maybe start comparing colors to a diagram.. Possibly 1ltr loom? Have never seen one though.
Post Posted: Wed Feb 15, 2012 7:59 pm
did you notice there is a broken pin on the blue plug???
Post Posted: Sat Feb 18, 2012 2:33 pm
hey mate U have a 1ltr dash loom and your one U bought is a 1.3ltr i had the same trouble i just cut the plugs off the 1.3ltr loom and put the 1ltr plugs on it by matching up the wires they should still all match bar ur pollution gear i just did mine i have a 1ltr zook with the 1ltr wiring loom i just went and got the motor side if it from wreackers which was 1.3 and change the plugs to fit into the 1ltr loom inside the cab
Post Posted: Mon Feb 20, 2012 8:48 am
Awesome i have dont this now :)
Once all the plumping is done and fuel lines run i should be ready to turn it over :)
Post Posted: Mon Feb 20, 2012 7:00 pm
thats good mate glad to know it worked :D
Users browsing this forum: No registered users and 51 guests
