It is currently Wed Nov 11, 2026 11:27 pm
Post Posted: Sun Jan 29, 2012 4:50 pm
i have got a type R temp gauge that im planing on putting in my jimny i was wondering how do i set it up the bottom left goes to the sender does anyone know what wire from the plug in the pics would be the sender wire i think ive got the right plug :? bottom goes to earth and the bottom right to ignition but what are the top 2 wires for?? its says to put these to dash light circuit what does it mean by this any help much appreciated
if u drive a loud toyota ute u drink rum
Vehicle: 2011 Jimny
Post Posted: Sun Jan 29, 2012 6:11 pm
by putting to the dash light circuit it will allow the light to turn on when you turn your lights on so you can see your gauge at night
Jimny's really do ROCK
Vehicle: 2011 Jimny
Post Posted: Sun Jan 29, 2012 6:13 pm
the black one is an earth red is light power so it only has power when light is turned on
Post Posted: Sun Jan 29, 2012 6:16 pm
k thanks i just wasnt sure if the other power one would do that any ideas on what wire is the sender from the engine
Post Posted: Sun Jan 29, 2012 11:57 pm
can any 1 tell me what wire is the sender??
Post Posted: Mon Jan 30, 2012 8:55 am
you'll need to run the aftermarket sender that came with the gauge, it's resistance will be calibrated to the gauge.
Post Posted: Mon Jan 30, 2012 11:59 am
where abouts do i put this in i couldnt see an area for it will i have to make a new hole?
Post Posted: Tue Feb 21, 2012 9:17 pm
can i use a old wire from the stock sender or will i have to put the new sender in
Post Posted: Tue Feb 21, 2012 9:24 pm
no cause the wire goes to the stock gauge in the dashboard, leave it alone & wire up the new gauge following the instructions.
you need to use the sender that came with the aftermarket gauge as it's resistance is calibrated to the temp range shown on the aftermarket gauge.
Post Posted: Tue Feb 21, 2012 9:27 pm
ok do you know if there is a spot for the sender in a jimny as i think the stock sender is completely different to the one with the gauge
Post Posted: Tue Feb 21, 2012 9:29 pm
NFI i don't do jimny's
why do you need an aftermarket gauge, maximum respect from the fast n furious crew?
Post Posted: Tue Feb 21, 2012 9:34 pm
haha nar i bought the gauge and gauge holder for my sierra due to its temp gauge didnt work but i sold it and now i thort sence i bought it i may aswell put it to use and they read the temp better and let you know if the temp going up b4 the stock unit does
Users browsing this forum: Google [Bot] and 81 guests
