It is currently Thu Nov 12, 2026 7:39 pm
Vehicle: Yamaha scooter, 50cc
Post Posted: Wed Mar 14, 2012 11:06 pm
I'm currently rebuilding a g13ba 8 valve and I've come across a little issue with the gasket kit I got. In the kit I've been supplied both an O-ring and a gasket for the distributor housing.
My question is which one should I use, or should I use both? If I use both, the gasket will cover the O-ring which kind of defeats the purpose of the O-ring.
Post Posted: Wed Mar 14, 2012 11:37 pm
Is the O-ring groove on the mating face or the perpendicular surface?
Post Posted: Thu Mar 15, 2012 3:02 am
The O-ring groove is on the same face that the gasket would sit on, you can see the O-ring in the first pic where my finger is pointing
Post Posted: Thu Mar 15, 2012 6:13 am
I'd use the o-ring. Don't use both
Post Posted: Thu Mar 15, 2012 7:29 am
I'd use the o ring. Baleno's have a similar thing for a cam sensor. Works fine.
If it leaks, you can always use the gasket later!
Vehicle: Bare shell lol
Post Posted: Thu Mar 15, 2012 7:45 am
if its got an o-ring grove go with the o-ring.
[IMG]http://i77.photobucket.com/albums/j51/bratboy[IMG]
Post Posted: Thu Mar 15, 2012 11:47 am
Cheers guys.
Post Posted: Sat Mar 17, 2012 12:30 pm
They are a major common leak spot here in the states. I would use a nice thin coating of your favorite sealant too.
Post Posted: Sat Mar 17, 2012 12:54 pm
+1
Not just the states.
Users browsing this forum: Google [Bot] and 72 guests
