It is currently Fri Nov 13, 2026 4:56 am
Vehicle: 2018 DMAX
Post Posted: Sat Mar 17, 2012 1:00 pm
Anyone have any tips for getting a stuck speedo output out? This thing is well stuck, I bent my vice grips trying to spin it out...
Post Posted: Sat Mar 17, 2012 1:20 pm
I know it is obvious, but is the set Bolt loosened?
Vehicle: 2018 DMAX
Post Posted: Sat Mar 17, 2012 1:45 pm
Yep its been removed... I have the case apart to change bearings, just cant get the last gears out.
Post Posted: Sat Mar 17, 2012 2:03 pm
Vise grips locked onto it and a screwdriver through through the jaws to twist it. Once it can wiggle it should pop out.
Rarely they call for a bit more effort to remove them..EG slide hammer.
Post Posted: Sat Mar 17, 2012 3:44 pm
I pulled mine out just then with needle nose pliers but it wasent Stuck try some crc and let it soak in then try again
Vehicle: 2018 DMAX
Post Posted: Sat Mar 17, 2012 5:55 pm
Did want33s trick and got it out in the end, had been soaking in WD40 overnight... There was a fair amount of sand in there.. Definitely tighter than other cases I pulled apart.
Users browsing this forum: No registered users and 69 guests
