It is currently Thu Nov 12, 2026 9:30 pm
Post Posted: Thu Mar 22, 2012 3:27 pm
is it wearth doing all wheel disc brakes or keeep the drum brakes
Vehicle: LWB Sierra & XL7
Post Posted: Thu Mar 22, 2012 3:31 pm
Does your zook have front drum brakes? :?
In the sense of improved braking performance, brake pads are cheaper than drums and easier to change. Yes it is wearth it.
'92 Vitara & Camper trailer
Post Posted: Thu Mar 22, 2012 3:45 pm
no i m thinking about doing a rear disc brake conversion so i have all round disc brakes
Post Posted: Thu Mar 22, 2012 4:07 pm
worth it if you drive alot of mud. other wise dont bother
Post Posted: Thu Mar 22, 2012 4:17 pm
ohk thanks
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Mar 23, 2012 3:53 pm
But if you keep them and do drive though mud make sure you open them up and clean them out whenever you do and avoid crashing into Toyota Celicas.
And houses.
Post Posted: Fri Mar 23, 2012 9:44 pm
Done both neo?
Post Posted: Fri Mar 23, 2012 10:44 pm
:lol:
Post Posted: Sun Mar 25, 2012 10:23 am
tanshi wrote:
worth it if you drive any mud. other wise dont bother
Rear drum brake lining life seems to be measured in hours if you drive in mud down here. That's the best reason to go to discs.
However, the semifloat axle drum brake kits I've seen leave some of the wheel bearing exposed, which seems to drastically reduce bearing life, so it's a double edged sword. I'm disc all round and would NEVER go back to rear drums, but they aren't without their complications, least of which is the loss of the wheel mounted handbrake, (depending on the kit/calipers used) chassis clearance, brake balance and pad choice/life are all issues to be resolved.
Post Posted: Mon Mar 26, 2012 7:25 pm
cheers steve
Post Posted: Wed Mar 28, 2012 10:32 am
I fitted the Ben T disc conversion to my 92 Vit recently. The best thing I ever did as far as brakes go. I now have rear brakes even after a serious day in the mud!!
Post Posted: Thu Mar 29, 2012 9:20 pm
Me too, and very happy with the brakes now.
Post Posted: Fri Mar 30, 2012 12:05 am
+1 :peaceout:
Vehicle: vits
Post Posted: Sat Mar 31, 2012 11:21 pm
+2 :peaceout: I haven't driven in mud but the Ben T disc kit feels like it has a lot more stopping power on the road than the drums. I have tested the brakes on dirt roads and didn't find any problems with the rear locking up first.
Users browsing this forum: No registered users and 66 guests
