It is currently Fri Nov 13, 2026 6:11 am
Post Posted: Sun Oct 30, 2011 10:02 am
:helloo: guys,
I would like to do a rear disk conversion on the jim. I have seen a few conversion kit's but can't seem to find much info about the kit's. There is the http://www.zanfi.it/modules.php?name=ca ... cts_id=987 kit bit hard to under stand some of that site :blink: so i would say that's a no go and there also the Giz kit, but i can not find any info on that at all, so pretty much use less to me :( .
Now, is there any reason the sierra 'benT' kit won't work? The only difference on the diff side of thing's i can think of are the width's of the rear diff on jimny compared to a sierra right?
Also would i have issue with the ABS? :? and what could i do for a hand break?
Cheers,
Andrew.
Post Posted: Sun Oct 30, 2011 12:06 pm
maybe just wait for the JML floater? then you get discs and a floaty bum bum.
Post Posted: Fri Mar 09, 2012 6:51 pm
Ok, i would really like to do this mod before winter. Can any one tell me what's going to happen with the ABS?
Post Posted: Sat Mar 10, 2012 11:17 am
Yeah, a handbrake would need to be added to the list. I thought that Sierra and jimny's essentially ran the same brakes. So I'm guessing that if Sierra and jimny's have the same brake shoe and pad numbers then it would work on assumption...
With this logic, would 4door vit brakes fit the front of a Jim? Ala the common Sierra swap???
Post Posted: Sat Mar 10, 2012 5:26 pm
Sierra rotors are different to Jimnys btw
Post Posted: Sat Mar 10, 2012 5:54 pm
http://www.bigjimny.com/images/document ... on_kit.pdf
heres a guide to fitting one. dunno about abs tho
Post Posted: Sat Apr 14, 2012 3:58 pm
I picked up some 4door rotors and calipers on the weekend will trial fit them soon.
Post Posted: Sun Apr 15, 2012 12:17 pm
http://www.youtube.com/watch?feature=pl ... Kk6Q#t=29s
Disconnecting ABS is bad mmmmkay? Surely theres rear discs/calipers off another vehicle that have a speed sensor sorted out already that will bolt on?
The JML floater kits use a handbrake adapter on the discs, so everything works as normal as far as that is concerned.
Post Posted: Mon Apr 16, 2012 10:49 am
i think i would be avoiding doing this on an ABS capable vehicle.
Sounds a little like playing with fire to me.
Post Posted: Mon Apr 16, 2012 5:06 pm
In regard to swapping front rotors on Jimnys, the VVT models have a larger centre hole so most other Zuke rotors won't suit a front upgrade/swap.
Users browsing this forum: Google [Bot] and 116 guests
