It is currently Thu Nov 12, 2026 1:44 pm
Vehicle: 84 Lwb Ute
Post Posted: Sat Apr 21, 2012 7:25 am
Hey all I got a 84 lwb Sierra and my horn won't work. Any onee know where the relay is for them as I can't seem to find it. Replaced the horn for a new one so has to be wiring. Any help would be great. Cheers
Post Posted: Sat Apr 21, 2012 7:34 am
Does the horn have a fuse? There's only 6 fuses in a 1 liter? I'd try there.
Vehicle: 84 Lwb Ute
Post Posted: Sat Apr 21, 2012 8:21 am
Checked all fuses and yes there's only 6 in the 1 liters but none are for the horn.
Post Posted: Sat Apr 21, 2012 9:12 am
Stupid question. Have you got the ignition turned on? My horns in the 1 liters won't work unless ignition is on.
Post Posted: Sat Apr 21, 2012 11:21 am
There is no relay for the horn.
It has constant power to the horn and is activated by earthing at the steering wheel.
Check you have power at the horn.
Check you have continuity to earth.
The problem is most likely the contact at the back of the steering wheel.
Post Posted: Sat Apr 21, 2012 11:25 am
or the steering shaft uni, or rag joint, dont think 1 litres had the earth bypass wire on them like later ones
Post Posted: Sat Apr 21, 2012 11:27 am
Mine used to come and go. It was weird. Must of been the contacts.
It was better when it wasnt working. Offroad, hit a bump, bip! Hi! :hey:
Post Posted: Sat Apr 21, 2012 11:33 am
My mate with the army green hilux's horn does that haha.
Vehicle: '94 suzuki maruti
Post Posted: Sat Apr 21, 2012 5:26 pm
i added a relay for my horn in my old sierra. used the original 2 horn wires as the relay trigger. upgraded to a horn i pulled from something from the wreckers, think it might have been an old falcon.,and wasnt sure if standard wires could handle it.
first things first, use a multimeter to check that its getting power first... im in gracemere and im free tomorrow, happy to lend a hand if needed.
Users browsing this forum: No registered users and 78 guests
