It is currently Tue Oct 20, 2026 6:08 am
Post Posted: Thu Apr 02, 2009 9:30 pm
Hiya all,
I need to flush the brakes on my GV shorty? Does anyone know much new fluid I will need to do a full flush, as oppossed to a bleed? Since they come in 500ml bottles it would really suck if I needed 600ml.
TIA
2002 SWB GV
Lifted and Locked
Post Posted: Thu Apr 02, 2009 10:22 pm
I reckon 2 bottles and bank on possibly heading off for another
you waste a fair bit flushing it cause it all mixes and if you strike a bubble you can go through a bit to get rid of it
if you have ABS you might need even more
Post Posted: Sat Apr 04, 2009 7:44 pm
Well it took just under 500ml (470ml maybe) and it appears to be flushed - colour changed from honey-amber to light blue (new fluid). I did pump the brakes a few extra times to make sure I got more blue coloured fluid out.
One thing I found strange is that there are only 3 nipples - RL, FL, FR with none on RR. I thought there would be 4. It appears the brake lines to RL go via RR. I don't have ABS.
There were no air bubbles and no spongeness when test driven :D :D :D
It seemed nearly too easy...
2002 SWB GV
Lifted and Locked
Post Posted: Sat Apr 04, 2009 8:06 pm
It is easy :D The no R/R nipple is pretty common, the later Sierras also have it along with a variety of other makes.
Users browsing this forum: No registered users and 307 guests
