| Author |
Message |
CompTruck
Joined: Mon Sep 21, 2009 11:30 pm Posts: 299 Location: brisbane northside
 Posted: Wed May 02, 2012 10:07 pm |
hi again mates. finally tracked down a transfer cars to replace my busted 6.5 geared one. have 31s on it that are close to real size. how craps it gunna be with my 1.3 big block engine in me sierra?
gotta do it though. wont be going up all the hills anymore for a while i guess. be able to do little red at glasshouse still with it? has a new standard clutch in it
JrZook
 Posted: Wed May 02, 2012 10:14 pm |
CompTruck wrote: be able to do little red at glasshouse still with it? This will most likely result in either: a) running into the trees or banks or upside down due to the speed you have to tackle it at to avoid stalling b) If not option a you will run outta clutch trying to tackle it sensibly.
_________________ Lil Foot!
CompTruck
 Posted: Wed May 02, 2012 10:23 pm |
ok betta not try it then. hope its still reasonable for smaller stuff just so i can get back out into the bush
JrZook
 Posted: Wed May 02, 2012 10:33 pm |
I only recall little Red years back when Royce actually wheeled and had his sierra. Even then it was a mission and you could really see to big tired vehicles struggle with control on standard gearing. They were bouncing into things and stalling all other the place! Entertaining to watch tho
CompTruck
 Posted: Wed May 02, 2012 10:39 pm |
yer its pretty extreme. lol
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed May 02, 2012 10:40 pm |
JrZook wrote: CompTruck wrote: be able to do little red at glasshouse still with it? This will most likely result in either: a) running into the trees or banks or upside down due to the speed you have to tackle it at to avoid stalling b) If not option a you will run outta clutch trying to tackle it sensibly. x2. It's crap.
_________________ mlm
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Thu May 03, 2012 9:02 am |
CompTruck wrote: have 31s on it that are close to real size. how craps it gunna be with my 1.3 big block engine in me sierra? . be able to do little red at glasshouse still with it? has a new standard clutch in it That would depend on how much clutch you want to burn - you may not have much clutch left by the time you get to the top... 31s are bad on standard gearing even with a 1.6...
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Thu May 03, 2012 12:57 pm |
JrZook
 Posted: Thu May 03, 2012 1:06 pm |
want33s
 Posted: Thu May 03, 2012 1:07 pm |
Yep... Standard transfers suck the dick.
JrZook
 Posted: Thu May 03, 2012 1:13 pm |
Would be an educational video for the fella's who believe in lockers before gearing once over-tyred. Just imagine the ridiculous speed you would have been pulling due to the added traction of lockers.
Crazy! Btw how the hell did those cv's hold up!
want33s
 Posted: Thu May 03, 2012 1:17 pm |
JrZook wrote: Would be an educational video for the fella's who believe in lockers before gearing once over-tyred. Just imagine the ridiculous speed you would have been pulling due to the added traction of lockers.
Crazy! Btw how the hell did those cv's hold up! They were fine that day but the next time I drove that track I did a RH.
CompTruck
 Posted: Thu May 03, 2012 2:52 pm |
looks pretty gay. atleast the car be useable again anyway
SierraDan
 Posted: Thu May 03, 2012 4:43 pm |
Not necessarily. You have to hit things with so much speed you don't have time to judge things that can happen. You could end up on your roof
JrZook
 Posted: Thu May 03, 2012 5:53 pm |
SierraDan wrote: Not necessarily. You have to hit things with so much speed you don't have time to judge things that can happen. You could end up on your roof  That would be option b) Eddie!
abclarke
Joined: Mon Feb 14, 2011 8:19 am Posts: 1966 Location: Couridjah
Vehicle: 1985 Holden Drover
 Posted: Thu May 03, 2012 7:40 pm |
SierraDan wrote: Not necessarily. You have to hit things with so much speed you don't have time to judge things that can happen. You could end up on your roof  I know that for a fact!
_________________ 1989 WT Sierra.
suzukikid
Joined: Sun Jan 14, 2007 10:30 pm Posts: 2803 Location: Melton Victoria!
 Posted: Thu May 03, 2012 7:49 pm |
i had 29's in my first one...with gearing....ended up on 33s but gearing is where its at!
now on 33s and 6.5s and its too low...but anyway... want33's ya made that look hard!haha
_________________ back in a built sierra!
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Thu May 03, 2012 8:00 pm |
suzukikid wrote: now on 33s and 6.5s and its too low... Depends on what you drive. I don't think 33's and 6.5's is too low at all- I'd say it's spot on for mixed technical driving. Steve
Joshyboy26
Joined: Thu Sep 01, 2011 11:48 pm Posts: 814 Location: kinglake, VIC
 Posted: Thu May 03, 2012 8:05 pm |
I had 32s and stockys for a while and it sucked donkey balls. i even had to get winched up a hill by a gutlux becuase my car physically couldnt turn the tyres! just embarrasing. mind you it was a friggen steep hill haha
_________________ I love lamp
Reubs
 Posted: Fri May 04, 2012 3:41 pm |
CompTruck wrote: looks pretty gay. atleast the car be useable again anyway 215s OR 235s would be more usable with the standard gears...
SierraDan
 Posted: Fri May 04, 2012 3:48 pm |
225's even
ZookFan
Joined: Mon Feb 14, 2011 6:19 am Posts: 3978 Location: Brisbane,samford,QLD
 Posted: Fri May 04, 2012 5:36 pm |
215s OR 235s would be more usable with the standard gears...[/quote] Don't forget that 215's while not huge is about 2 inch's bigger than the stock rubber...
So like going to 31's on a Hilux, Rodeo, BT50
remydog05
Joined: Sun Nov 23, 2008 10:30 pm Posts: 1260 Location: Vic
 Posted: Fri May 04, 2012 5:59 pm |
i had a swb wt and 30's I killed clutches trying to slow it down for control all the time.
Daves4wd
Joined: Fri Aug 26, 2011 3:17 pm Posts: 1286 Location: Melbourne
 Posted: Fri May 04, 2012 10:32 pm |
30s sucked balls with no gearing and still is shit house with 3.9 diffs and a 1 liter case still not low Enough for some hills great for big holes but
SierraDan
 Posted: Fri May 04, 2012 10:37 pm |
4.16 reduction gears aren't too bad.
CompTruck
 Posted: Sat May 05, 2012 12:23 am |
i dunno what reduction il go with next time. didnt mind it with the 6.5s. only drive glasshouse. like crawling up things with the twin lockers. used 1st doin little red. did all my steep ones in 1st. would probably go again with same gears. but havent sampled any others lol
i shud probably confirm they are 6.5s. they are super low though i know that much
tanshi
 Posted: Sat May 05, 2012 9:05 am |
for 31s i only ever recomend 4.9s but thats just me
