It is currently Fri Nov 13, 2026 5:39 am
Post Posted: Sat May 12, 2012 10:46 am
I would like to know what the best place would be to hook up the trigger for a relay when the ignition is in the 'on' position?
Post Posted: Sat May 12, 2012 2:18 pm
Are you running a switch in cab as well? Just pick it up from anything that has power when ignition is on. Use a test light and find a wire under the d ash. That's how I run my gauge lights.
Post Posted: Sat May 12, 2012 2:50 pm
A. I don't have a test light. B. why would I spend 30 mins wriggling around under the dash when someone on here can probably tell me?
Post Posted: Sat May 12, 2012 3:36 pm
Cause you have to you lazy lil prick.....
Oh, & black wire white stripe :wink:
Post Posted: Sat May 12, 2012 3:40 pm
Thanks for the hint Mr Stek. :youdaman:
Post Posted: Sat May 12, 2012 3:42 pm
Run a thematic switch & a over ride switch in the cab, so it can't cut in when in water......
Post Posted: Sat May 12, 2012 7:04 pm
That's the plan! :P
Post Posted: Sun May 13, 2012 5:08 am
Use a cross over relay and a warning light that comes on when fan is switched off. This way you will have a reminder to switch back on again.
Pete
Users browsing this forum: No registered users and 78 guests
