It is currently Fri Nov 13, 2026 5:24 am
Vehicle: 1985 Sierra Hardtop
Post Posted: Sat May 05, 2012 2:34 pm
hello,
i'm having major issues with my brakes ( 1985 Sierra Hardtop ) after replacing everything, as in have no pedal.
i have done/replaced:
master cylinder
front pads
seal kits and new pistons in front calipers
rear wheel cylinders
rear shoes
new drums
brake bleeding/new fluid
the problem is no matter what i do i have no rear brakes, as in the rears don't work but the front does. they have been bled many times, everythings, visually, is as it should be as far as i know. when i lock off/clamp the rear lines ( clamp the rubber sections going over the diff ) the brakes ( fronts ) work fine, have proper pedal etc. as soon as i un-clamp the rears i end up with no pedal again?? anyone have any ideas on what i may have done wrong or what else to do/check??
cheers
Chris
Post Posted: Sat May 05, 2012 4:20 pm
did you adjust them properly?
Post Posted: Sat May 05, 2012 10:40 pm
that's the bit i can't figure out, they seem to be adjusted as far out as possible but dont seem to come out far enough? if that makes sense
Vehicle: 1999 Jimny
Post Posted: Sun May 06, 2012 6:38 am
I'd re-check the adjustment on the rears & see how you go. You didn't have any bits missing or left over??????
Post Posted: Sun May 06, 2012 7:12 am
My guess is wrong shoes, there's two different sizes. Did you compare them before fitting? If not then compare them now
Post Posted: Sun May 06, 2012 7:14 am
Can the different ones even go in?
I got the small ones when i needed the big ones once, and it physically wouldnt go one the handbrake/adjuster thing.
Post Posted: Sun May 06, 2012 7:19 am
I managed to fit some when I was in hurry once, had the same thing happen
Post Posted: Mon May 07, 2012 10:19 am
did some mearsurements and it looks like the new drums are too big in internal diameter! the shoes are adjjusted as far out as possible and still dont touch the drums hence the no rear brakes!! how or why i dont know but here is between 8 and 10mm difference between the diameter of the drum and the shoes fully adjusted out.
Post Posted: Mon May 07, 2012 1:48 pm
Wrong size shoe. There are two different size drum on Sierras, I think they are something 180 and 200mm
Post Posted: Mon May 07, 2012 4:10 pm
i dont think its the shoes, i have the same as what came off. drums measure around 228mm internal diameter and say maximum 230mm, shoes measure at 220mm fully adjusted out as far as they go.
Post Posted: Mon May 07, 2012 5:01 pm
Have you compared shoes by eye or by placing new and old together?
Are the wheel cylinders right?
Post Posted: Mon May 07, 2012 5:46 pm
yes and yes, old and new shoes are identical and wheels cylinders are the same as what came off. the only thing we can find nt\ot right is the drum size?
Post Posted: Mon May 07, 2012 5:54 pm
So you have the bigger drums meant for the bigger shoes then.
Post Posted: Mon May 07, 2012 6:02 pm
put the old drums on?
Post Posted: Mon May 07, 2012 6:13 pm
i posted all this before we realised the drums could have been wrong!!!
old drums were well cactus so got chucked, fingers crossed it'll be sorted tomorrow as i rang the shop that i got all the parts from and it looks like thay have the smaller drums available. it sucks though cause i told them all the info required and they never said anything about there being different sizes of shoes and drums! wouldn't have had all this head f*#k if they had have said to check the sizes or said there were differences
Post Posted: Wed May 09, 2012 9:26 pm
wrong sized drums it was! all sorted now
Post Posted: Thu May 10, 2012 5:31 am
I had a hell of a time adjusting the back brakes on my '87 LWB NT.
At the end I had to use a screwdriver and lever the shoe out, and the adjuster sprung out and took up the slack.
Pedal ok now, but after a drive, one drum is warm, the other cold.I'll pull it apart and adjust it out a bit more.
How's it done? Is there an easier way?
bye
Vehicle: nt sierra
Post Posted: Thu May 10, 2012 4:11 pm
wtf. arnt all the drums self adjusting? except the handbrake.
Post Posted: Thu May 10, 2012 4:17 pm
once i had the correct parts mine was a piece of piss, the adjusters did their own thing and adjusted up nicely, i just had to close them up to get the drums on then a couple of pumps on the pedal and all was good. brakes feel bloody good now!
Post Posted: Fri May 11, 2012 9:19 am
My 1.0 litre LWB did not have self adjusters,
until I upgraded to 1.3 brakes.
I don't know if other models also didn't have self adjusters.
The 1.3 brakes were much nicer,
but not as nice as the later disc conversion.
Post Posted: Fri May 11, 2012 9:27 am
bye
Are your brakes full of mud? I'd be stripping them apart and making sure everything works properly. Free up and grease the adjusters. Are all the springs fitted correctly?
Post Posted: Sat May 12, 2012 4:36 am
All brake parts look as new.Springs on right???Took one side off at a time,but everything seemed to work.
I just can't see why one side remains cold, not working at all?
bye
Vehicle: 1989 Suzuki Sierra W/T
Post Posted: Sun May 13, 2012 6:22 pm
Hello,
I need help with the brakes on my '89 Sierra W/T.
The handbrake cable appears too long even when fully adjusted. When driving the handbrake lever must be on to make the brake pedal work properly, otherwise it goes to the floor. we put a spacer in the cable the keep tension and now the lever moves only seven clicks but does not work - only makes the pedal brakes work better still. When the handbrake is on the shoes don't seem to come out far enough, only a few millimeters. My drum is 220mil, the same as my friends N/T but it seems as though my shoes aren't extending far enough to reach the drum. The adjusters are fully extended too.
Any help will be appreciated. Thanks
Post Posted: Sun May 13, 2012 6:41 pm
Is not Royce trying to help you on another post?
Post Posted: Sun May 13, 2012 6:44 pm
jmrc94 wrote:
Hello,
Have a look here. This fellas having a similar problem.
viewtopic.php?f=5&t=32566
Post Posted: Sun May 13, 2012 7:01 pm
Bwhahahahahaha
Post Posted: Sun May 13, 2012 7:47 pm
thanks for the link. dont know how i missed that one...
Users browsing this forum: Google [Bot] and 74 guests
