It is currently Fri Nov 13, 2026 1:52 am
Vehicle: Jimny
Post Posted: Tue Jul 17, 2012 7:58 pm
Hay guys just wonder would a gti twin cam head fit on a g13bb motor???
Can it be done???
Has anyone done this??? Could u give me some pointers???
Does it help with power/ torque etc???
Cheers cookie :peaceout:
hit it HARD or GO HOME!!!!
Post Posted: Tue Jul 17, 2012 8:08 pm
Wouldnt it be exactly the same?
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Jul 18, 2012 6:24 am
I'm pretty sure they are I heard that the most of difference is in the computer
Green? greeeen is nice !
Vehicle: '94 suzuki maruti
Post Posted: Wed Jul 18, 2012 8:02 am
i would think it'd be the same issue as putting a 16 valve vitara head on an 8 valve vitara block...
Vehicle: Jimny 99 2" lift, 31s etc
Can u put a twin cam head on a single cam motor? Like a standard sierra motor
if u don't get stuck u ain't trying hard enough
Vehicle: Jimny
Post Posted: Wed Jul 18, 2012 8:32 am
It's a standard Jimny motor
Vehicle: SJ51T
Post Posted: Wed Jul 18, 2012 8:46 am
nope.
Post Posted: Wed Jul 18, 2012 8:55 am
Not at all. A g13BB is a 16v motor, so a 16v G13B head should be fine. The BB head and vitara head are VERY similar (may even be the same casting), and we know that a G13B head bolts onto a G16B block.
IMO, you should just swap in the complete G13B motor. It has a stronger bottom end, and you won't have to stuff around with timing belts etc.
Post Posted: Wed Jul 18, 2012 9:08 am
But check legalities before hand.
When did the gti's motors end production?
older motor is a newer car is a no no
Post Posted: Wed Jul 18, 2012 2:13 pm
G13BB is 16 Valve but SOHC
GTi is 16 Valve DOHC.
Totally different head but it will fit.
Users browsing this forum: Google Adsense [Bot] and 27 guests
