It is currently Thu Nov 12, 2026 10:14 pm
Vehicle: 1996 Suzuki Sierra Soft Top
Post Posted: Sat Aug 11, 2012 9:23 pm
Seeking some advice.
I have a 1992 Sierra (219000 kms on the clock). Juat purchased so don't know the real history behind it.
Sometimes when i go to start it and turn the key, i get a horrible scratch noise, and the motor doesnt turn over. I turn the key again and it will start.
2nd problem, When i press the clutch i can hear a rattling noise, when i release the clutch it goes away.
Thoughts?
Post Posted: Sat Aug 11, 2012 9:59 pm
first of all, welcome to AZ & what an awesome user name. :lol:
i'm no sierra expert, but the first issue sounds like the starter motor isn't meshing properly with ring gear on the fly wheel, it could be a worn starter motor or at worst a worn ring gear. your second problem sounds like it's the thrust/release bearing. pretty cheap to replace the bearing, but the gearbox or motor has to come out... while it's apart you're better off putting a clutch kit through it & get the fly wheel machined. (clutch kit will have the release bearing)
Vehicle: Yellow Ute
Post Posted: Sat Aug 11, 2012 10:23 pm
Rattling noise with clutch in could also be the spigot bearing in the flywheel, worth replacing with the clutch.
Post Posted: Sun Aug 12, 2012 7:57 am
That starter issue has been in both sierras i've owned and a few others ive seen.
Users browsing this forum: pete_79 and 59 guests
