| Author |
Message |
reeceh
Joined: Thu Apr 29, 2010 8:45 am Posts: 1230 Location: Brisbane
Vehicle: 91 sierra, g16b,lift,30's
 Posted: Mon Oct 08, 2012 1:46 pm |
Ok so I'm in the process of the head removal of my 1.6. I've removed the whole intake manifold, dropped the extractors off and lifted the tappet cover.
What's the next step from here. Do I have to mark anything in relation to the timing before I pull the dizzy out etc etc
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Mon Oct 08, 2012 1:49 pm |
I just yanked the cam out and proceeded to remove the head bolts.
You'd probably have to re adjust the timing anyways, but you will see marks of where the bolts were to use as reference.
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Mon Oct 08, 2012 1:58 pm |
With the work you're going to be doing on it, I wouldn't worry about the timimg, just set it up when you put it back together.
reeceh
 Posted: Mon Oct 08, 2012 2:00 pm |
A friend told me I should be winding the eng over to top dead centre?
zukmeista
 Posted: Mon Oct 08, 2012 2:18 pm |
It won't matter, just line it up when you put it together, as you will be removing the cam anyway.
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Mon Oct 08, 2012 2:46 pm |
zukmeista wrote: It won't matter, just line it up when you put it together, as you will be removing the cam anyway. This.
reeceh
 Posted: Mon Oct 08, 2012 3:08 pm |
Ok sweet and do I just pluck the whole dizzy off? Also when removing the timing belt cover does it slip out from behind the pulleys.
buzbox
 Posted: Mon Oct 08, 2012 3:13 pm |
Yep just remove the complete dizzy from the head. Undo the cam pulley bolt but don't remove it, just loosen it, It will help talking the cam out later. Then remove the belt, Save time and just cut it off. Surely you will be replacing it anyways.
reeceh
 Posted: Mon Oct 08, 2012 3:28 pm |
Ok sweet. This is my first real engine mechanical work. So I want to be 100% before I do it. Also I take it the position of the cam is not important as it will only go back in one way??
mnemonix
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1409 Location: Newcastle NSW
Vehicle: '96 LWB trayback
 Posted: Mon Oct 08, 2012 4:06 pm |
Are you planning to replace your head studs when refitting the head?
buzbox
 Posted: Mon Oct 08, 2012 4:23 pm |
reeceh wrote: Also I take it the position of the cam is not important as it will only go back in one way?? exactamundo What I will be doing is getting the block and head work done then take the whole thing back to the reco place or mechanic to mate them back together. It'll save alot of swearing and having to buy a torque wrench. and yes, While the head bolts arn't torque to yeild, It's a good idea to have them replaced anyways.
reeceh
 Posted: Mon Oct 08, 2012 4:39 pm |
Part of me wants to tilt tray the bucket of shit to a shop and hand over the dosh to come back and drive it home. Also the whole warranty thing. However I've never touched the inside of any engine and seeing as it will be my bush basher id like to know how it all goes back together. I've got a few mechanic mates with torque wrenches. So that will be sweet. Suziauto told me you can reuse head bolts. If there easy and cheap enough to get ill get some!
zukmeista
 Posted: Mon Oct 08, 2012 6:15 pm |
reeceh wrote: Ok sweet and do I just pluck the whole dizzy off? Also when removing the timing belt cover does it slip out from behind the pulleys. You will need to unbolt the cam and crank pullies, best to crack the bolts with the fanbelt on to stop them fom turning.
reeceh
 Posted: Mon Oct 08, 2012 7:58 pm |
mnemonix wrote: Are you planning to replace your head studs when refitting the head? I've been told I should replace them and been told I can reuse them!
