It is currently Sat Nov 07, 2026 10:52 am
Post Posted: Mon Oct 08, 2012 5:33 pm
The vitara that I am robbing bits from for my Sierra has headers with a single wire 02 sensor, the plug looks like it should be a 4 wire 02 sensor. The single wire is dodgly joined to the loom behind the plug. Should I get a new 4 wire sensor or will the single wire jobbie be ok?
Post Posted: Mon Oct 08, 2012 5:39 pm
4 wire is a heated sensor. 5 times the price, and does the same thing once the motor is up to temp.
Post Posted: Mon Oct 08, 2012 6:00 pm
My balenos G16b's have been 4pin plug. 1 wire oxy sensor.
Post Posted: Mon Oct 08, 2012 6:24 pm
So it won't affect how it runs?
Post Posted: Mon Oct 08, 2012 6:35 pm
Nope.
Vehicle: 91 WT 1.6EFI
Post Posted: Mon Oct 08, 2012 6:57 pm
I have the same style g16b as your using shep and mines four pin plug with only the one black wire running to the extractors
Post Posted: Mon Oct 08, 2012 9:12 pm
+1 wot them sed.
Post Posted: Tue Oct 09, 2012 6:37 am
Mine, too, only one wire into a 4pin plug.
Guess thats the plugs they had on hand :)
Post Posted: Tue Oct 09, 2012 6:42 am
Mine has had a wire cut from the plug and the sensor wire is attached with something similar to a scotch lock. Def not factory
Post Posted: Tue Oct 09, 2012 8:09 am
I think the 4 wire O2 sensor was for north America and Europe. Not sure I've seen an Aussie delivered G16 with a 4 wire....
I'd say that your scotch locked wire was broken at some point. That, or the O2 sensor is from another vehicle, and it was easier to butcher the wire than swap the plug or pin over.
Post Posted: Tue Oct 09, 2012 10:11 am
Aftermarket sensors don't come with the plug, so easier to cut the old wire and tap in.
Users browsing this forum: Google [Bot] and 80 guests
