It is currently Fri Nov 06, 2026 4:49 pm
Post Posted: Sun Oct 28, 2012 4:32 pm
Got a suzuki grand vitara 1999, broke the rear door handle. Pretty common I hear. So bought one of those unbreakable one from ebay. Broke that too. Are there any other options ?
Post Posted: Sun Oct 28, 2012 7:18 pm
I have read somewhere that you can get an alloy one but cannot remember where from.....
Post Posted: Sun Oct 28, 2012 7:28 pm
How old is the unbreakable handle. What ebay seller did you buy it from?
Post Posted: Mon Oct 29, 2012 12:00 pm
I believe the "unbreakable" handles are marketed by ODA.
There's a design flaw in the OEM handle assembly that allows them to flex & break - the OEM handle uses two pivot pins, and this allows the "fixed" part (that bolts to the door) to flex when you lift the moving part - if the fixed part flexes too much, the moving part breaks - replace the two pins with a single full length pin and you eliminate (or at least significantly reduce) the flex.
Post Posted: Mon Oct 29, 2012 12:10 pm
Lube your links and locks?
Users browsing this forum: Google [Bot] and 60 guests
