It is currently Sat Nov 07, 2026 10:52 am
Post Posted: Sat Nov 05, 2011 7:44 am
what is the size socket needed for the big nut washer thing in the hubs when changing wheel bearings?
1991 suzuki Sierra
Post Posted: Sat Nov 05, 2011 7:46 am
50mm I think
Post Posted: Sat Nov 05, 2011 8:10 am
Roger that.
Post Posted: Sat Nov 05, 2011 8:15 am
Try to get a socket that has teeth all the way to the edge..... Sounds funny :crazy: but some don't and will work well for the outside nut but will slip on the inside one.
Thanks guys! Is that the same as a hilux one? I have a hilux one in the shed I think, But I got a feeling its 52mm
Post Posted: Sat Nov 05, 2011 8:19 am
I understand man haha
Sierra is 50mm..
Toyota is 52mm...
Post Posted: Sat Nov 05, 2011 8:20 am
wander if I can get away with the 52 ;)
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Sat Nov 05, 2011 8:24 am
You talking about the nut thing with a tabs behind it? on the shaft...
If at first you don't succeed, get a bigger hammer
Post Posted: Sat Nov 05, 2011 8:25 am
You won't be able to tighten it enough
Post Posted: Sat Nov 05, 2011 8:28 am
Yeah i'll have to buy correct size before I strip it and then im fucked
Post Posted: Sat Nov 05, 2011 8:38 am
Use a Chisel
Post Posted: Sat Nov 05, 2011 8:41 am
ridzilla wrote:
Use a Chisel
How do you tension it up with a chisel :helloo:
Post Posted: Sat Nov 05, 2011 8:43 am
Where is a good place to buy one at a reasonable price??
Post Posted: Sat Nov 05, 2011 9:07 am
I've been using a 52mm for years. Never had an issue.
Post Posted: Sat Nov 05, 2011 9:14 am
THANK YOU ! Now I have possibly saved time and money !
Post Posted: Sat Nov 05, 2011 9:23 am
I have even used a 55,, pipr socket on them, and achieved the required torque settings as outlined in the sevice manual.
Its not best practice by any means, but it works....
Post Posted: Sat Nov 05, 2011 9:24 am
Good enough for me!!
Vehicle: 1985 Holden Drover
Post Posted: Sat Nov 05, 2011 9:27 am
Sounds dodgy, but to get me out of trouble once at work we used a bigger sized socket and just ran a small strip of steel around the nut. Still worked too :lol:
1989 WT Sierra.
Post Posted: Sat Nov 05, 2011 9:33 am
i bought a flash one from lowrange.
http://www.lowrangeoffroad.com/index.ph ... ocket.html
Post Posted: Sat Nov 05, 2011 11:52 am
this one go's all the way in
http://www.trailtough.com/index.php?pag ... &Itemid=53
 Profile YIM
Post Posted: Sat Nov 05, 2011 6:14 pm
Rusho wrote:
ridzilla wrote:
Use a Chisel
With a hammer & ninja skill past down for generation's... :helloo:
Vehicle: 90 hardtop and 89 soft top
Post Posted: Wed Nov 14, 2012 10:13 am
I have used a 54mm socket before without problemos
Post Posted: Fri Nov 16, 2012 7:26 pm
you can order them in from repco
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Fri Nov 16, 2012 8:37 pm
ive used a 72mm socket before. Worked a treat
Post Posted: Fri Nov 16, 2012 9:29 pm
Can I borrow it to do mine?
Post Posted: Fri Nov 16, 2012 9:35 pm
What's wrong with your teeth ??
Post Posted: Fri Nov 16, 2012 9:37 pm
Tartar build up. got to get that fixed one day :roll:
Post Posted: Sat Nov 17, 2012 6:02 am
It's all that tartar sauce. Get off the shit
Users browsing this forum: Google [Bot] and 81 guests
