It is currently Fri Nov 06, 2026 5:53 pm
Vehicle: 2003 V6 Grand Vitara (SQ625)
Post Posted: Tue Nov 20, 2012 12:44 pm
Does anyone know how to clean these or do they just need to be replaced?
There is alot of corrosion and rust which is preventing contact points.
See pics :)
http://www.auszookers.com/forum/viewtopic.php?t=36934
Post Posted: Tue Nov 20, 2012 9:37 pm
I didn't even know those things come apart!
If they're giving you issues i'd say try to give the contacts a good clean and see if you can get them going again - steal wool and wd40 maybe?
Post Posted: Tue Nov 20, 2012 10:23 pm
Yeh it's just a rubber sleeve that slips onto a 10mm barb but there is a bolt on the inside that i wasn't able to remove, so i just used some wd-40 and scratched up the bolt to make better contact.. Idles beautiful now :D.
Post Posted: Wed Nov 21, 2012 1:30 am
I use a small "cup style" wire brush in a Dremel rotary tool.
Post Posted: Wed Nov 21, 2012 4:36 am
Ah yeah i was thinking of buying a dremel 4000 as they can be so handy. :)
Vehicle: 2002 Suzuki XL7
Post Posted: Wed Nov 21, 2012 7:30 am
I always wondered how long these coil packs last, seen the price of them vary a lot, but never heard or read of one failing.
But now you have made me want to check mine... :)
Post Posted: Wed Nov 21, 2012 11:11 am
They do fail occasionally - I haven't had any on my GV fail, but my sister has had two go on her V6 Vitara. In addition to the coils there's also an ignitor transistor inside them.
Post Posted: Wed Nov 21, 2012 11:27 am
Luckily i kept the old ones out of my other GV i had as these arn't cheap and no rust on these :)
Users browsing this forum: Google [Bot] and 90 guests
