It is currently Fri Nov 13, 2026 3:44 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Post Posted: Thu Jan 10, 2013 12:32 pm
Mate the 5 inch lift you have is a silly setup and you will have clearance issues with the firewall if you fit 31 inch tyres.
Seriously have a look through my build thread and see what mine is like after I threw all the stupid bits away from the 5 inch calmini setup. Just keep the springs and put fatzooks shackles in the stock position( ya need the shackles as the calmini springs are very long) and then you will have Clearance for 33 inch tyres. I have 33x10.5x15 tyres and the only issue I have is the tyre trying to remove the headlights at full compression.
Post Posted: Thu Jan 10, 2013 1:25 pm
god damn it man, y u not search and wheel it stock for a bit? btw irrelevant info but went from 28"s to 33"s with 2" lift, you mad bro?
Post Posted: Fri Jan 11, 2013 12:28 pm
Did they fit Jake?
Vehicle: Suzuki sierra
Post Posted: Fri Jan 11, 2013 6:06 pm
The dude seid the rims would fit a sierra but thy didn't now I got to find new rims anless stock rims can fit 10.5 inch wide tyers
Post Posted: Fri Jan 11, 2013 6:08 pm
No. Stock rims can't fit 10.5" tyres safely.
Post Posted: Fri Jan 11, 2013 6:11 pm
you don't want to fit a 10.5" wide tyre to a 10" wide rim, they just won't hold the bead.
15x7's in the correct offset will be perfect for that size tyre.
So they won't hold them
Post Posted: Fri Jan 11, 2013 6:20 pm
a stock rim is 15x5.5...
Post Posted: Fri Jan 11, 2013 6:37 pm
Ok thanks
Users browsing this forum: No registered users and 81 guests
