It is currently Fri Nov 06, 2026 12:33 pm
Vehicle: '92 Sierra
Post Posted: Tue Jan 15, 2013 11:49 pm
Just a quick one because it's late! Does anyone know an Australian seller for the thru-firewall studs below? It's for relocating my battery under the PS seat.
Also would the terminal fuse block in the link below be acceptable for the main fuse before the run to the fuse panel? What size fuse should I use with it? They've got from 30A to 300A?
http://www.ebay.com.au/itm/Blue-Sea-519 ... 416ae89bcb
Cheers,
John
Vehicle: sj51
Post Posted: Wed Jan 16, 2013 5:10 am
Regaurding the fuse size, total the amperage of all the fuses that will be running from it and use that as your baseline
Post Posted: Wed Jan 16, 2013 5:42 am
VPW for Moroso feeder studs.
Steve
Post Posted: Wed Jan 16, 2013 6:12 am
make the fuse smaller than the cable can handle, though 60amp would be more than enough
why not just run the cable through some glands? I dont like the idea of those studs, 2 more places can become exposed and short, plus 2 more places to corrode and drop voltage
Post Posted: Wed Jan 16, 2013 6:38 am
X2 would be cheaper also :peaceout:
Post Posted: Wed Jan 16, 2013 7:12 am
We've used them on a number of cars for years. They work well.
Users browsing this forum: No registered users and 24 guests
